10-07-2015, 13:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | need htc m8w firmware format logs Code: Operation : Format FileSystem [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 57 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040507A143946151 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040507A143946151 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! read info Code: Operation : Check / Read Info [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 57 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040507A143946151 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040507A143946151 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HTC_M8w ProdName : HTC_M8w ProdModel : HTC_M8w Device : HTC_M8w AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_1_wg_n Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
11-18-2015, 09:13 | #3 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2004 Location: Pakistan
Member: 51218 Status: Offline Thanks Meter: 77 | Quote:
Why did you format,always use search ,do AV and than Full factory reset. wr KHAWAR | |
12-01-2015, 12:34 | #4 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi guys.. anyone has this fw..? anyone read out the backup from working phone..? MT6582__HTC_M8w__HTC_M8w__HTC_M8w__4.4.2__ALPS.KK1 .MP1.V2.10 and preloader file; preloader_th55.bin |
