01-10-2008, 00:51 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
01-10-2008, 15:18 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @berwan Please, check my instruction again: http:///vbb/showpo...33&postcount=2 also you can try this pinout: 1: Gnd 7: Rx 16: Tx |
01-12-2008, 22:47 | #6 (permalink) | |
Hello, I have prepared more easy-to-understand instruction: Currently many "Chinese" models with the same name but absolutely different hardware exist on market, f.e. exist at least 20 phones with name "Chinese Nokia-N95" but with different bottom connectors and different pinouts, so we recommend you to include the next information in your question regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 | |
01-13-2008, 19:46 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! in 5 pin connector no need any autopinout finder. there is 1 pin GND, another is charging PIN, so only 3 free pins left. this gives only 6 possible combinations of tx/rx can be checked in 15min |
08-01-2008, 14:32 | #10 (permalink) |
No Life Poster Join Date: Jan 2002 Location: freak land Age: 44
Member: 8866 Status: Offline Thanks Meter: 50 | having in mind that there are so many pins ...i suppose i cannot check all manually ...so .... i have pinfinder ...wich cable should i use and where to solder pins ? 10x in advance! |
08-02-2008, 11:32 | #11 (permalink) | |
Use PinFinder cable with free wires, solder wires everywhere. Select 24-pin cable in PinFinder and try to detect pinout. | |
Need 8600 Luna MT6226 PC Sync & USB Driver | fronline | Chinese Models & Cloned Phones | 8 | 04-07-2010 06:44 |
Need EU Box PinOuts and Alcaatel C635 Pinouts | Formingus | Easy-Unlocker | 3 | 01-22-2009 23:41 |
i need v100/vbox pinouts | jonqrandom | Motorola Old Legacy (EMMI) | 4 | 03-09-2005 17:30 |
Need Motorola T205 pinout | Bemsas | Motorola ODM | 2 | 10-28-2001 21:19 |
Need 100% real pinouts for Motorola M series. | Bogi | Motorola Old Legacy (EMMI) | 3 | 09-02-2001 13:55 |
