Old 02-21-2011, 13:09   #1 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 267
need to improve operations on 6253
i have ever failed to format whenever encountered a cpu 6253(only back up can be made)
Device: Autodetect 6253 NOR
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== [2/21/2011 3:48:50 PM] ====
COM50 [VCP0] selected
module v3.26
Action: reset settings ("format ffs")
Model: Autodetect 6253 NOR
Checking data, wait...
19200 autodetect
Initializing [6253:8A02:8A00]...
CPU: MT6253
high speed boot On
chip: 0000:0000:000F
status: FF
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button more long time !
error: operation failed !
Finished, time used: 1 min 19 sec
Remove/Install battery now !
Old 02-21-2011, 13:10   #2 (permalink)
Member: 190344
Thanks Meter: 267
Loading data, wait...
[Infinity Box] Chinese Miracle v3.25
smart-card: connected
S/N:
Wait...
Device: Autodetect 6205-6239 NOR
Done
==== [2/18/2011 4:36:27 PM] ====
module v3.25
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
warning: wrong packet cs
Finished, time used: 30 sec
==== [2/18/2011 4:37:15 PM] ====
module v3.25
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Finished, time used: 57 sec
==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [2/18/2011 4:38:45 PM] ====
web site: Infinity-Box - About
support forum in English: Infinity-Box - GSM-Forum
Infinity-CDMA Tool
BB5 Easy Service Tool -
PinFinder Adapter
[Infinity Box] Chinese Miracle v3.26
S/N: 66F0:0116
Wait...
Done
Device: Autodetect 6228-6253 NAND
==== [2/18/2011 4:39:00 PM] ====
module v3.26
Model: Autodetect 6228-6253 NAND
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Finished, time used: 29 sec
==== [2/18/2011 4:39:49 PM] ====
COM50 selected
module v3.26
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Finished, time used: 1 min 26 sec
Old 02-21-2011, 13:14   #3 (permalink)
Member: 190344
Thanks Meter: 267
==== [2/1/2011 4:41:30 PM] ====
COM39 [VCP0] selected
module v3.26
Model: Autodetect 6205-6239 NOR
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Release Power button now !
Phone detected, wait...
warning: can't read software version, probably unknown firmware
detecting structure #2...
0 1 2
==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [2/1/2011 4:42:13 PM] ====
Infinity-CDMA Tool
PinFinder Adapter
S/N:
Wait...
Done
==== [2/1/2011 4:42:26 PM] ====
COM39 [VCP1] selected
module v3.26
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35error: detection failed (36 tries), read flash and send to support
connection lost
Finished, time used: 1 min 23 sec
In most cases you can read "firmware" instead of "full flash",
it may helps to save a lot of time with the same functionality.
Suggestion: read "firmware" now
Do you want to read "firmware" instead of "full flash" ?
==== [2/1/2011 4:44:04 PM] ====
module v3.26
Action: read firmware NAND
interface: BROM_DLL_v3.1016.00
Connect...
bootcode current/expected: 0.0/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D
chip size: 0Mb
otp status/size: S_DONE/00000000
NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C
chip size: 0Mb
page/spare size: 0000/0000
pages per block: 0000
bits i/o: 00
address cycles: 00
internal RAM size: 00000000
external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000
error: can not boot device: 07E9:S_BROM_LOCK_POWERKEY_FAIL
error: last error: 07E9:S_BROM_LOCK_POWERKEY_FAIL
Disconnect...
done
Finished, time used: 8 sec
==== [2/1/2011 4:44:15 PM] ====
module v3.26
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash id[00C1]: 00EC:240400000000 [SAMSUNG] K5N2833ATB
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 00000000/00000000
detect sec ro...
detect custom parameters...
detect project-id...
project-id: C100.XT.NASAKI01.100926.02
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: TELSDA53_SLIM_09A_PCB01_GPRS_MT6253_S00.C100_XT_NA SAKI01_100926_02.BIN
project-id: C100.XT.NASAKI01.100926.02, 00000000
code offset: 00000000
ffs offset/size [02]: 00E00000/00200000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.26, database date: 19.01.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
area size: 14Mb
number of areas/bytes to read: 1:00E00000
file saved: C:\Documents and Settings\Administrator\Desktop\TELSDA53_SLIM_09A_P CB01_GPRS_MT6253_S00.C100_XT_NASAKI01_100926_02__f irmware_20110201-165205.B0M.bin
Disconnect...
done
Finished, time used: 8 min 0 sec
Old 02-21-2011, 22:00   #4 (permalink)
Member: 148515
Thanks Meter: 13,685
hello!
we are working under improving our software
Old 02-22-2011, 18:18   #5 (permalink)
ahmedzameer's Avatar
Member: 431754
Thanks Meter: 30
waiting for new update..............
thanks
Old 02-27-2011, 06:08   #6 (permalink)
Member: 1043909
Thanks Meter: 49,267
Hello,
Please, try to use this new software:
http://www.infinity-box.com/download...dule_v3.77.rar
1. select model Huawei-G6620
2. make full flash backup for emergency case !
3. try to repair imei (DO NOT try to make other operations, this software for imei only)
Please, post here operation log.
Waiting for your results.
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 17:24
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 12:35
Page generated in 0.35689 seconds with 8 queries
