Old 12-18-2015, 19:25   #1 (permalink)
Member: 322417
Thanks Meter: 940
Need info about this error. Thanks
Card found : S/N : CB822A50 , v0129
Chinese Miracle II  [MTK module] v 1.39
Operation : Check / Read Info [ v1.39 ]
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 110100303034474530011D0AB5C0C139
DA Stat : v4.2 on BBID : 0x88
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
Error : DA init Failed! Error code : 0x5
LErr : EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:26
Reconnect Power/Cable!
Thanks in Advance
Old 12-19-2015, 08:17   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
If you try flash dead phone with FW - then it mean it not compatible with that phone.
If you just connect phone and NO fw selected - then it mean :
-BootKey pressed
-Phone erased
And in SW internal DB no such EMI for this FlashIc.
Old 12-19-2015, 13:04   #3 (permalink)
Member: 322417
Thanks Meter: 940
-BootKey pressed
-Phone erased
I will get this info on flash , read info , repair ect
What is your suggestion ?
Old 12-19-2015, 13:17   #4 (permalink)
JayDi's Avatar
Member: 462970
Not hold BootKeys. Just cable in phone.
After , if it will connect - read FW, and send me "preloader.bin" file from it, will update EMIDB in SW.
Old 12-19-2015, 20:16   #5 (permalink)
Member: 322417
Thanks Meter: 940
Same error on read
Thanks any way lets leave this set
Old 12-20-2015, 05:29   #6 (permalink)
JayDi's Avatar
Member: 462970
When find such emi - will add. It not easy without having some files, or phone on hands.
Page generated in 0.14601 seconds with 8 queries
