03-12-2015, 11:18 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | need lenovo s660 NV file mtk 6582 cpu set come network issue( imei ok) 1 side shows emergency and 1 side network operator name I did try to get back up ( no success ) then format ( with ( no 10 option) set shows ( download dl fail) so I download og firmware and flashed set alive but still no network issue) need some help thank you. |
03-12-2015, 11:28 | #3 (permalink) | |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
but same tool DL image fail Code: Chinese Miracle II [MTK module] v 1.15 Operation : Format FileSystem [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D420146AC544D4129 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D420146AC544D4129 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Already exist FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! Operation : Fix DL Errors [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004B3758564D420146AC544D4129 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D420146AC544D4129 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Phone not require that operation!!! Done! Elapsed: 00:00:20 Reconnect Power/Cable! also not make it alive Code: Phone not require that operation!!! | |
03-12-2015, 13:18 | #5 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Download Factory Firmware Flash It By Code: SP_Flash_Tool_exe_v3.1316.0.150 Code: Da DL All With Check Sum Post Result@ | |
