06-13-2015, 10:33 | #4 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | Quote:
so he send it to me. when i boot it . it boot OK . but i do a mistake that i didn't take a backup and format it. now when i insert a charger or usb cable its now blinking. so can you send me the flash file | |
06-13-2015, 10:40 | #6 (permalink) |
Member: 442808 Status: Offline Thanks Meter: 195 | Here is the log. Operation : Check / Read Info [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ADEEECF14E6ADD06DAC60000F20EFD26 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00FFE000 , 0x00002000 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Format FileSystem [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 27 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : ADEEECF14E6ADD06DAC60000F20EFD26 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00FFE000 , 0x00002000 Backup FFS error! Executing FFS FORMAT now... FAT_RANGE : 0x00DE0000-0x00FFDFFF , LEN : 0x0021E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
06-13-2015, 12:22 | #7 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Here is link for file- https://drive.google.com/file/d/0B6K...ew?usp=sharing Br. | |
02-12-2016, 17:15 | #13 (permalink) |
Junior Member Join Date: Aug 2015 Location: India
Member: 2445151 Status: Offline Thanks Meter: 1 | I need micromax X2814 flash file. it was blinking.very urgent here is volcano log Analysis of USB port,Please insert phone USB cable. Connecting... Hardware version:CB00 Software version:0000 CPU TYPE:6260 Internal version:8000 Boot downloading complete! Flash ID: 00EF006000180000 Chip Capacity: 0x1000000(16MB) Baud adjust...complete. |
02-12-2016, 17:17 | #14 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
02-14-2016, 07:21 | #15 (permalink) |
Member: 2445151 Status: Offline Thanks Meter: 1 | i was in big trouble. help very urgent.X2814 flash file. it was blinking.very urgent here is volcano log Analysis of USB port,Please insert phone USB cable. Connecting... Hardware version:CB00 Software version:0000 CPU TYPE:6260 Internal version:8000 Boot downloading complete! Flash ID: 00EF006000180000 Chip Capacity: 0x1000000(16MB) Baud adjust...complete. |
