Old 08-21-2008, 08:12   #1 (permalink)
Mang mel's Avatar
Member: 218941
Thanks Meter: 1,801
need myphone s22 Fullbackup
need my/phone s22 Fullbackup....
Old 08-21-2008, 22:09   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please post software version readed in "Read detailed information" mode
Old 08-22-2008, 04:52   #3 (permalink)
Mang mel's Avatar
Member: 218941
Thanks Meter: 1,801
PHONE IS DEAD..
Do you want to continue ?
COM17 [VCP2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22022201:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00700000
checking area[00000000]: 00000000-007FFFFF...
eeprom/ffs found near: 00700000
detecting eeprom/ffs size...
eeprom/ffs size: 00100000
ffs chip: 00
eeprom/ffs area: 00000000:00700000-007FFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 63 sec
Remove/Install battery now !
Old 08-22-2008, 21:44   #4 (permalink)
Member: 148515
hello!
damaged firmware, program failed to get out version.
you can try to search for flash files in support area by phone model
and try one by one, if you will find different
Old 08-23-2008, 04:42   #5 (permalink)
Mang mel's Avatar
Member: 218941
Thanks Meter: 1,801
I have tried S21 BUT CAn'T flash...
Old 08-23-2008, 20:41   #6 (permalink)
Member: 148515
hello!
what means "cant flash" ? what error do you face?
MyPhone S22 Duo PCB Pinout needed Badly!! marvin03 Infinity-Box 1 11-28-2009 12:37
I need help myphone s22 duo dead ayhen42 Infinity-Box 4 04-23-2009 23:30
>>> MyPhone S22 DUO SIM2 SHUTDOWN solved <<< keaelite Infinity-Box 15 09-21-2008 01:41
help myphone s22 change imei error ayhen42 Infinity-Box 5 09-21-2008 01:41
Page generated in 0.18692 seconds with 10 queries
