09-17-2008, 16:26 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>> LG KP235 unlocked Successfully <<< Big thanks to Infinity Team >>>>> Device: LG-KP235 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 352127022272095xxxxx file saved: C:\Program Files\InfinityBox\LGA\eeprom_3521270222xxxxx_LG-KP235_20080917-173424.B1E.bin .... Check flash Done Check space... current eeprom imei: 3521270222xxxxx .................................................. .............. finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 38 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to zeel_zeel For This Useful Post: |
09-17-2008, 17:50 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
>>> LG KU990 Unlocked Successfully <<< | cellcarekphb | Easy-Unlocker | 5 | 02-11-2009 18:40 |
>>> LG CU920 Unlocked Successfully <<< | zeel_zeel | Easy-Unlocker | 1 | 02-05-2009 09:58 |
>>> LG KG276 Unlocked Successfully <<< | zeel_zeel | Infinity-Box | 2 | 01-31-2009 05:17 |
>>> LG CU500v unlocked successful <<< | zeel_zeel | FuriousGold | 6 | 09-11-2008 06:40 |
>>> LG KG130 unlocked success <<< | zeel_zeel | Infinity-Box | 4 | 08-25-2008 06:46 |
