02-14-2010, 08:46 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post connector type. are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
02-14-2010, 17:23 | #3 (permalink) |
Freak Poster Join Date: May 2007 Location: South Africa Age: 44
Member: 505446 Status: Offline Thanks Meter: 45 | Guys please must not forget to give full details before sending request for any pin outs. 1-System connector type 2-full information from the imei labl 3-manufacturer name(eg mobicel,mobitel,LC,etc etc) 4-picture of the phone if possible Last edited by InfinityHelp; 02-15-2010 at 12:40. |
01-16-2011, 22:45 | #6 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 330758 Status: Offline Thanks Meter: 12 | operation n97 rm-505 read full flash, not work COM8 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 17 sec Remove/Install battery now ! __________________________________________________ on/off boot autoselect and not work again cable 1x5 , how do? how read full flash??? __________________________________________________ ___ operation user/lock code _________________________________________________ COM8 [VCP0] selected module v3.26 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ONECOM.09AW0932.W3598 Version: ONECOM_09A_HW detecting structure #2... 1 4 5 8 9 11 12 done 90 byte(s) read imei: 35422503001066 connection Ok detecting structure #1... 0 1 7 8 9 12 14 15 16 18 19 25 26 27 30 32 33 34error: detection failed (18 tries), read flash and send to support error: can't read required data error: operation failed !Finished, time used: 18 sec Remove/Install battery now ! |
01-18-2011, 17:08 | #9 (permalink) |
Member: 330758 Status: Offline Thanks Meter: 12 | flashing, nokia n97 china mobile rm-505 hi, i sucessfull flash for changue lenguaje spanish, this log: COM8 [VCP0] selected module v3.26 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: write flash NAND write: Firmware CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598__firmware_20110117-171624.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: CELLONSZ35_09A_BOOTLOADER_V005_MT6235B_ONECOM_09AW 0932_W3598.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: ONECOM.09AW0932.W3598 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: CELLONSZ35_09A_BOOTLOADER_V005_MT6235B_ONECOM_09AW 0932_W3598.bin warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN project-id: ONECOM.09AW0932.W3598, 5B7CF5DB code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done nfi area detection... bootloader version: CELLONSZ35_09A_BOOTLOADER_V005_MT6235B_ONECOM_09AW 0932_W3598.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235.[CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN_DBF57C5B].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.00006235._CELL ONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0932_ W3598.BIN_DBF57C5B_.rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235.[CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN_DBF57C5B].rpl rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.00006235._CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01. ONECOM_09AW0932_W3598.BIN_DBF57C5B_.rpl ==================== warning: unknown firmware: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN_DBF57C5B Unknown firmware found (v.3.26, database date: 13.01.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... Disconnect... done Finished, time used: 51 min 42 sec Remove/Install battery now ! DONE.... BUT PHONE NOT POWER ON, HOW DO? |
01-18-2011, 17:24 | #10 (permalink) |
Member: 330758 Status: Offline Thanks Meter: 12 | Info firmaware SORRY MULTIPOST.... I CANT EDIT MY POST THIS IS INFO FIRMAWARE FOR FLASHING: Loading file v.02... CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598__firmware_20110117-171624.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN project-id: ONECOM.09AW0932.W3598, 5B7CF5DB code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2009-11-11 15-01 hw1: ONECOM_09A_HW hw2: 09A_CELLONSZ35_09A detecting languages... Languages: En Ru Gr Fr Es Hu It Ro De Ml Id Th Vn Cn Farsi Pt Cn A |
01-19-2011, 00:28 | #11 (permalink) | |
Code: ==================== warning: unknown firmware: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN_DBF57C5B Unknown firmware found (v.3.26, database date: 13.01.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ35_09A_PCB01_GPRS_MT6235B_S01.ONECOM_09AW0 932_W3598.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== | |
need n82 pinout urgent | tolski | Infinity-Box | 10 | 02-20-2009 04:25 |
Bluetooth N97 Pinouts needed | zeerik | Infinity-Box | 3 | 12-22-2008 08:58 |
i need c168 pinouts urgent | brain00000 | Infinity-Box | 1 | 10-19-2008 18:55 |
nokia 8800 pinout urgently need | domestik | Phoenix Black Box | 5 | 06-29-2005 16:03 |
NEED sharp GX10 Pinouts... URGENT.. | DrMobile | Wanted Products | 4 | 04-07-2003 07:14 |
