06-18-2012, 14:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 199538 Status: Offline Thanks Meter: 54 | Need new flashes for G7210 Huawei panama SUPPORT !!! I try to put thw two flashes in support : Huawei-G7210_MIRROR_HW_C251_PCB01_GPRS_MT6236_S00.G7210SS _C251_M40_00_26.BIN_FLNTY9A0A111300KA40_2011-07-17_En_Es_Panama-CU.B4M.bin Huawei-G7210_MIRROR_HW_PCB01_GPRS_MT6236_S00.G7210SS_C236 _M40_00_23.BIN_FLNTY9A0A111300KA40_2011-05-21_En_Fr_Es.B4M.bin Now the phone is Totally DEAD .... I was Reading and just a New Flash with new BOOT ver. 5.1152 in GPGDRAGON resolve this problem ... here the post : http://forum.gsmhosting.com/vbb/f646...7/#post8386035 Can support or any body Share this nexts Flash to resolve the problem of the g7210 HUAWEI panama new boot DEAD : MIRROR_HW_C238_BOOTLOADER_V005_MT6236_G7210SS_C238 _M40_00_09.bin MIRROR_HW_C238_PCB01_GPRS_MT6236_S00.G7210SS_C238_ M40_00_09.BIN_FLNTY9A0A111300KA40 thanks advanced |
06-18-2012, 18:07 | #3 (permalink) |
Member: 199538 Status: Offline Thanks Meter: 54 | here logs .. please support see that and compare with the link i put in the first post here about new Boot done with gpgdragon thanks advanced === [18/06/2012 08:56:04 a.m.] ==== COM6 [VCP0] selected module v4.31 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7210_MIRROR_HW_PCB01_GPRS_MT6236_S00.G7210SS_C236 _M40_00_23.BIN_FLNTY9A0A111300KA40_2011-05-21_En_Fr_Es.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... incorrect ext bootloader signature: 10B500F0 bootloader version: MIRROR_HW_BOOTLOADER_V005_MT6236_G7210SS_C236_M40_ 00_23.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6236:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0055]: 0098:00B100000055 [TOSHIBA] TC58NYG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00018000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6236:8A02:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: G7210SS_C251_M40_00_26 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: MIRROR_HW_C251_PCB01_GPRS_MT6236_S00.G7210SS_C251_ M40_00_26.BIN_FLNTY9A0A111300KA40 project-id: G7210SS_C251_M40_00_26, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... incorrect ext bootloader signature: 10B500F0 bootloader version: MIRROR_HW_BOOTLOADER_V005_MT6236_G7210SS_C236_M40_ 00_23.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... write core... Disconnect... done Finished, time used: 9 min 54 sec Remove/Install battery now ! 2nd flash ==== [18/06/2012 08:43:51 a.m.] ==== COM6 [VCP0] selected module v4.31 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7210_MIRROR_HW_C251_PCB01_GPRS_MT6236_S00.G7210SS _C251_M40_00_26.BIN_FLNTY9A0A111300KA40_2011-07-17_En_Es_Panama-CU.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... incorrect ext bootloader signature: 10B500F0 bootloader version: MIRROR_HW_C251_BOOTLOADER_V005_MT6236_G7210SS_C251 _M40_00_26.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6236:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0055]: 0098:00B100000055 [TOSHIBA] TC58NYG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00018000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6236:8A02:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: G7210SS_C251_M40_00_26 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: MIRROR_HW_C251_PCB01_GPRS_MT6236_S00.G7210SS_C251_ M40_00_26.BIN_FLNTY9A0A111300KA40 project-id: G7210SS_C251_M40_00_26, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... incorrect ext bootloader signature: 10B500F0 bootloader version: MIRROR_HW_C251_BOOTLOADER_V005_MT6236_G7210SS_C251 _M40_00_26.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... write core... Disconnect... done |
06-18-2012, 19:43 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, it may be that your phone should be flashed with another flash file. open operation.log file and try to find log text for first flashing attempt. In that log we can see what was phone original firmware version. |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
