07-22-2009, 08:07 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 775560 Status: Offline Thanks Meter: 58 | need by pass kalibration for this file A615 ! http://rapidshare.com/files/258613045 |
07-22-2009, 09:33 | #2 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Quote:
07-26-2009, 20:39 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! read out full flash and send it to [email protected] write subject "all calibration modes failed on this firmware" |
07-27-2009, 12:10 | #5 (permalink) |
Member: 775560 Status: Offline Thanks Meter: 58 | i already send this file to [email protected] at 25/07/2009 the link of backup file still same http://rapidshare.com/files/258613045 please help me for sure ! |
07-28-2009, 22:28 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i asked to send it to [email protected] please see BIZ at the end, not COM. also, after you send us some firmware this version will be supported in next CM update. |
07-29-2009, 22:30 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to calibrate touchscreen (if toucscreen panel is damaged): 1. connect cable from box to phone 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model 6. go to software "Settings" page and select COM port 7. make full flash backup for emergency case 8. go to software "Service" page 9. select calibration "mode-1" 10. make "Reverse calibration order" un-checked 11. press "Calibrate touchscrren" button and follow instruction given by software 12. if software can not make calibration with "detection failed" error: - select other calibration mode (f.e. "mode-2", "mode-3" etc. one by one) - repeat calibration process - test phone after each "mode" try 13. if calibration process finished without errors but touchscreen can not work well: - DO NOT change calibration "mode" ! - make "Reverse calibration order" option checked - repeat calibration process again - test phone 14. if still no luck with calibration after all tries: - make full flash backup for emergency case - make "format ffs" - Power-On phone - Power-Off phone by "Power" button (do NOT remove battery) - Repeat "Calibration" operation again - if still no luck read full flash and send to support with subject: touchscreen calibration failed |
07-30-2009, 06:47 | #9 (permalink) |
Member: 775560 Status: Offline Thanks Meter: 58 | the phone now working well becouse i change the lcd module include the touchscreen also ! for calibration method already i try like infinity team says but no luck for me ! this is the backup file for working K Touch A615 _ TYM073245_411_PCB04_GPRS_MT6228_S02.073245_411_V13 45__nand_firmware_20090721-132636.B4M TO CHANGE THE CORUPT ONE IN THE SUPORT AREA http://rapidshare.com/files/261636028 JUST FOR 10 TIME DOWLOAD |
08-06-2009, 23:24 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Touchscreen calibration procedure changed, ChineseMiracle v2.88 released: http://forum.gsmhosting.com/vbb/showthread.php?t=801258 Please, try to calibrate phone with new software, waiting for your results. |
i need epprom for this file | G$m | Infinity-Box | 0 | 02-24-2010 15:51 |
need by pass package | ummhere | SETool2 | 2 | 08-16-2009 17:02 |
need help for this file | .::Indian::. | Chinese Models & Cloned Phones | 0 | 08-29-2008 08:51 |
Newbie Need Help For This File | rkinfo_imran | SpiderMan | 1 | 07-26-2008 22:29 |
Need pass for this files... | legija | Off Topic Zone | 0 | 03-12-2002 08:19 |
