01-28-2009, 18:47 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Sir, Plz Add Trend T303 Model. I try to Pan01.exc Model Select Trend T101 but this error software version: 1.17 cable type: 1x18 (L18A) platform: PMB: Infineon e-gold searching adapter at COM5... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (820000) result: Rx:11 Tx:12 time required: 99 sec Power On ! COM5 [VCP1] selected module v1.60 Device: Trend-T101 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .00 ULC2GL 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-static_20090128-224629.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-security_20090128-224630.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Trend-T101_eeprom-complete_20090128-224631.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware error: set erase range error: erase failed: 00000000 Write Failed Finished, time used: 22 sec Remove/Install battery now ! |
DAXIAN x999+ 10 pins need pin-out | mak_14344 | Infinity-Box | 3 | 07-15-2009 22:10 |
Need pin out of Trend T103 | Qaisar Mahmood | Infinity-Box | 7 | 03-03-2009 15:33 |
need help cect _t688+ ...cect_i658. need pin outs | arfantanveer | Infinity-Box | 9 | 12-04-2007 00:34 |
Need pin-out for C45 | -=GSM2002=- | x1x to x45/x50 | 3 | 04-05-2002 11:21 |
I need pin out for Siemens C30 | Spalato | NON Siemens Brand (ODM Phones) | 0 | 12-19-2000 12:56 |
