Old 10-02-2010, 10:12   #1 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
Need pinout
Need Nokia N100i dual sim pinout dual sim
i cant find Rx & Tx
CPU :Mt6226a
Old 10-02-2010, 11:23   #2 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
i think is wrong pinout !!!!!!!!!!!!!!!!!
COM3 [VCP1] selected
module  v3.22
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 2 sec
Remove/Install battery now !
Old 10-03-2010, 11:12   #3 (permalink)
Member: 148515
Thanks Meter: 16,145
hello!
yes, posted above log is with wrong pinout
what is connector type?
did you try pinfinder?
Old 10-03-2010, 18:11   #4 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
I did not pinfinder
i have this error in more phone...; i think, i have prob in my infinity
http://forum.gsmhosting.com/vbb/f425...ction-1102171/
Motorola F3 damaged pinout
Old 10-04-2010, 10:23   #5 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Originally Posted by MMDEBILI View Post
I did not pinfinder
How is it possible to talk about problems with box if you just unable to find pinout ?
Please, explain what box problem you talk about, I want to understand it well.
Old 10-04-2010, 20:08   #6 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
MY BOX WORK 100000000000000000% SORRY Infinity TEAM
Successfully unlocked/repaired phones by Infinity-Box
Old 10-05-2010, 18:16   #7 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
Disassemble the phone and check PCB for the RX TX points..
If you not found a RX TX on PCB you have to check voltages on USB connecter for find the RX,TX. check this example.
Explain to find pinout on 12 pin usb connector.
1. At first, you need to find GND signal (3pin-00.2v)
2. The second step: you need to find Tx Rx signals. Choose the pinouts, that may probably suit. You have 12 pinouts:
1pin-0.00v - this pinout is wrong
2pin-2.78 - it may correspond to Tx Rx signals
3pin-00.2v - GND signal
4pin-2.75v - it may correspond to Tx Rx signals
5pin-1.09v - LOOKS LIKE Tx Rx signals, BUT IT IS NOT!
6pin-0.00v - this pinout is wrong
7pin-4.02v - this pinout is wrong
8pin-2.89v - it may correspond to Tx Rx signals
9pin-3.05v - this pinout is wrong
10pin-0.00v - this pinout is wrong
11pin-1.09v - it may correspond to Tx Rx signals
12pin-0.02v - YOU DON'T NEED these fake signals with high and low voltage
3. In order to find Tx you need to put multimeter to test, diod ( "+" and "-" = beep ).
When the phone is POWERED ON, Tx with GND make a sound beep.
When it is TURNED OFF, it shows 600-700 ohm.
It is suggested to do all the job using wire connection.
After following the above mentioned steps you'll find, that 2pin is Tx and 8pin is Rx. Tx has to be 1.7v or 2.7v and Rx - 1.8v or 2.8v. These characteristics may change depending on the processor parameters. But Tx and Rx is not the same. Tx can be 2.78v, 2.75v, 2.7v.
The Following 2 Users Say Thank You to MMDEBILI For This Useful Post:
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 18:04
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.30962 seconds with 8 queries
