03-31-2008, 18:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Algeria
Member: 483440 Status: Offline Thanks Meter: 191 | need pinout need pinout N95 double sim 12 pin (i love you) i tested: 1 GND 6 RX 7 TX but dont worked tnx Br Hichem edited: sorry for posting in wrong section! |
03-31-2008, 18:16 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
03-31-2008, 20:00 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! very bad quality photo. maybe you can make it better? also, you must try pinout basing on GND poistion pin, not on connector type only. please check where is GND pin in your case. if it is not pin 1- then no point to even try mentioned above pinout |
03-31-2008, 21:17 | #9 (permalink) |
Freak Poster Join Date: May 2005 Location: B-GHEDIR ALGERIA Age: 52
Member: 142664 Status: Offline Thanks Meter: 14 | n95 Check the conecter because i think the problem is in your phone because the N95 in the pict is same like i formated and i worked with a lot with this pinout . |
i needded pinout cect s500 pinout | anildeepak | Infinity-Box | 5 | 05-04-2008 09:38 |
InfinityHelp i need your help. need pinouts | IkaMazini | Infinity-Box | 3 | 02-22-2008 20:04 |
n95 bluetooth 2x6 single sim pinout not work need pinout | walid1751 | Infinity-Box | 4 | 11-13-2007 15:40 |
need pinout of nspro and pinout of all cables | cobra02a | NSPRO | 2 | 10-23-2006 20:33 |
need pinout for Nokia 3520 or 3560. very need | sp-lox | Nokia CDMA | 1 | 12-30-2003 20:59 |
