Old 10-11-2008, 13:27   #1 (permalink)
az cells's Avatar
Member: 115516
Thanks Meter: 113
sigmatel s3
sigmatel s3
COM3 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:AC03:0000
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20081011-175256.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
.damaged firmware
.damaged hardware
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
error: error# 000000FF
error: flash write error: 00000000:00002000
2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BF
C2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BF C2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BF
C2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC3B3B591E1A2E3B3B3B7 92E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BF
C2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BF C2E3B3B3BF42E3B3B3B8ED71E451E331E3AC4C4C43B3B3B3B1 A2E3B3B3BFC
error: wrong answer: 95
Write Fail
Finished, time used: 574 sec
Remove/Install battery now !
whats the problem
plz help
Old 10-11-2008, 13:40   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what is used as cable?
here was similar problem: http:///vbb/showth...=428416&page=2
sigmatel s3 camera module not ready jobykjoseph Chinese Models & Cloned Phones 63 10-07-2009 15:49
Got Solution Sigmatel S3 White Screen nazar2008 Infinity-Box 8 11-08-2008 09:30
Sigmatel s3 camera module not ready,Hot Solution mobileunlockerz Chinese Models & Cloned Phones 7 09-03-2008 10:29
sigmatel s3 not work with sim Imrankhan Infinity-Box 4 05-24-2008 16:09
help for china sigmatel s3 nazar2008 Infinity-Box 3 05-24-2008 08:24
Page generated in 0.13858 seconds with 10 queries
