02-16-2010, 10:27 | #3 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
05-14-2010, 15:15 | #5 (permalink) | |
Freak Poster Join Date: Nov 2005
Member: 201062 Status: Offline Thanks Meter: 37 | Quote:
05-15-2010, 11:39 | #7 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | Cable name: Alcatel-OT-C701 connector 2x5 /1 2 3 4 5\ |6 7 8 9 10| 4: %tx% 5: %rx% 6: %gnd% ==================== points near sim card 1 2 3 4 5 6 7 8 9 1: %vbat% 2: %gnd% 3: %rx% 4: %tx% try with this pinout... |
10-27-2010, 15:06 | #9 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Vojvodina Age: 45
Member: 44395 Status: Offline Thanks Meter: 7 | Alcatel OT-E211 pinout I done it this way! the usb connector way dont worked for me! |
The Following User Says Thank You to microtel For This Useful Post: |
11-08-2010, 06:47 | #10 (permalink) |
No Life Poster Join Date: Nov 2008 Location: nakodar
Member: 903492 Status: Offline Sonork: 1590666 Thanks Meter: 571 | yas bro i done it COM11 [VCP0] selected module v3.62 Device: Alcatel-660X, 660A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7303:A004 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:08EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.1D352 7C5.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_EE8AFA9F].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 1D3527C5 rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 9FFA8AEE code offset: 00020000 ffs offset/size [01]: 01000000/00FE0000 TCL-ID identification version: 335 provider: 660X-2DTBGB1 customization: CJ33DH08 customization: XJ33DH08 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01000000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:08EA0000000000 flash: 98006F00000004:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ33DH08 customization name adjusted flash: 98006F00000004:08EA0000000000 flash: 98006F00000004:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:08EA0000000000 flash: 98006F00000004:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ33DH08 customization name adjusted flash: 98006F00000004:08EA0000000000 flash: 98006F00000004:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:08EA0000000000 flash: 98006F00000004:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35238703317009 flash: 98006F00000004:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:08EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-660X,660A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__system_log_1D3527C5_EE8AFA9F_2010 1108-111259.B0X.bin Finished, time used: 5 min 15 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ^^^RAVI SOOD^^^ For This Useful Post: |
Unlock code for Alcatel OT 660 | Sami101 | Phone Unlocking Codes & Maps | 8 | 06-10-2012 19:34 |
Alcatel OT-660 E100 Flip dead after unlock, Supporter Please Help | brokendreem | Infinity-Box | 25 | 01-26-2012 14:57 |
Alcatel OT-660 E100 Flip dead after unlock, Supporter Please Help | dauyeuqn | Infinity-Box | 9 | 10-24-2010 00:05 |
Needs rx tx alcatel ot-660. | aleem26 | Infinity-Box | 2 | 12-30-2009 20:02 |
i need pinout of alcatel ot-v570 | aliazer | Infinity-Box | 2 | 10-13-2009 22:45 |
