Old 08-19-2009, 04:37   #1 (permalink)
Member: 411831
Thanks Meter: 215
need pinout CL75 siemens for infinity
hello friends i need pinout (rx-tx)CL75 siemens for infinity.
i don't have cable.
thank you.
Old 08-19-2009, 04:51   #2 (permalink)
howell's Avatar
Member: 697643
Thanks Meter: 68
heres your request boss
The Following 2 Users Say Thank You to howell For This Useful Post:
Old 08-19-2009, 06:39   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 08-19-2009, 09:48   #4 (permalink)
Member: 411831
Thanks Meter: 215
@howell
thanks to help.
but i need rj45 cable pinout.for unlock.
not usb cable.
thank i hope you help me.
Old 08-19-2009, 10:07   #5 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,299
Originally Posted by msantar View Post
@howell
thanks to help.
not usb cable.
ordinary Siemens x5x, x6x cable
The Following User Says Thank You to shahzaadbutt For This Useful Post:
Old 08-19-2009, 12:53   #6 (permalink)
Member: 411831
Thanks Meter: 215
yes sir i know i can use ordinary Siemens x5x, x6x cable .
but i don't have that one, may i loose.
thatsway i need pinout way.
thanks .
Old 08-19-2009, 13:22   #7 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,417
thanks .
here you can see
http://pinouts.ru/CellularPhones-P-W...5_pinout.shtml
Faisal_Computer
The Following 2 Users Say Thank You to Faisal_Computer For This Useful Post:
Old 08-19-2009, 15:31   #8 (permalink)
Member: 411831
Thanks Meter: 215
thank to all my respected sir & infinity box
it's done
COM8 [VCP0] selected
Device: Siemens-CL75
Checking data, wait...
Action: Unlock
Boot...
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22202200:98E59F00000000
flash: Amd PL127J D 16Mb
Boot Done
Set baud...
115200
Set baud Done
Check Flash...
Check Flash Done
Check space...
file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-1_20090819-061852.21E.bin
file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-2_20090819-061856.21E.bin
Check space Done
Check parameters...
Check parameters Done
Format file system...
area-01...
area requested/selected: 02/03
Format file system Done
Write...
Preparing...
Finalizing...
Write Done
Finished
Remove/Install battery now !
Time used: 42 sec
The Following User Says Thank You to msantar For This Useful Post:
Old 08-19-2009, 15:45   #9 (permalink)
Member: 151871
you most welcome !!
Faisal_Computer
Need add "MTK_Resource_Edit" soft for infinity alamgir80 Infinity-Box 6 04-09-2009 20:09
i need all china cables for infinity [email protected] S Infinity-Box 10 02-27-2008 19:59
i need zt321 flash file for infinity. faramarzi376 Infinity-Box 2 12-03-2007 09:09
Need pinout on CPU for Motorola T205\T2688 sed_alex Motorola Hardware Repair 2 12-08-2002 17:18
Page generated in 0.28713 seconds with 8 queries
