01-07-2008, 04:41 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
06-03-2009, 22:07 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
I need help. need pinout for 6060v RH-97 | IkaMazini | HWK | 1 | 07-26-2008 07:22 |
need help for cect T680 | kiran | Chinese Models & Cloned Phones | 1 | 03-09-2008 08:52 |
Working GX10i pinout for handset manager needed. | chris_ua | Sharp | 0 | 01-30-2005 14:32 |
need pinout for Nokia 3520 or 3560. very need | sp-lox | Nokia CDMA | 1 | 12-30-2003 20:59 |
