02-12-2008, 20:13 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @::. ziz .:: Dear Friend, Currently many "Chinese" models with the same name but absolutely different hardware exist on market. Exmple: exist at least 20 phones with name "Chinese Nokia-N95" but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 |
02-16-2008, 09:23 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: sarcelles Age: 47
Member: 161061 Status: Offline Thanks Meter: 568 | i have found cable usb i said that i can modified cable to make cable rj45 with same pinout cable usb tx _____tx rx_________rx gnd _________gnd true or false ithink that same pinout rj45 and usb tell me if i am not true ps connecteur like must samsung 18 pin |
02-16-2008, 16:12 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! no, you can not use USB cable D+, D- wires to connect with phone Tx/Rx. box RJ45 port give out TTL level signals, but USB giving USB level. so to get working cbale you must take rx/tx out from rj45 connector. |
@infinity team need pinout for KD B86 KENUO | simpleboy | Infinity-Box | 11 | 01-29-2009 11:34 |
kenuo kn-76d | lhakkaoui | Chinese Models & Cloned Phones | 1 | 09-25-2008 15:06 |
kenuo kn-d9 dead after format | GalaxyMan | SpiderMan | 3 | 02-26-2008 17:23 |
KENUO KN-D8 pinout? | dogeatdog | Infinity-Box | 6 | 01-23-2008 21:53 |
need pinout for myv-76 | FMC_GSM | SAGEM JTAG UNLOCKER | 1 | 12-16-2007 09:50 |
