12-27-2009, 07:01 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Need pinout for KINSEN-P83 the connector is same as infinity cable "Z-1000" theres is no rx, tx i found on the pcb. plz help |
12-27-2009, 21:22 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! even if pins are not marked- worth to measure voltage on all of them. phone battery attached, phone powered On. if you see on any pins voltage between 2,7 and 2,9 volts- this is Tx/Rx |
12-28-2009, 19:44 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! take multimeter, set voltage measuring mode. one probe set to some grounded part. with another probe touch one by one all system connector pins or test points. look for measured values. memorise pins with 2,7...2,9 volts. they are Tx/Rx remmember, phone must be with attached battery and powered On |
Need help I need pinout for this chinese phone | cayton_l | Infinity-Box | 9 | 12-03-2008 19:22 |
I need help. need pinout for 6060v RH-97 | IkaMazini | HWK | 1 | 07-26-2008 07:22 |
need pinout for Nokia 3520 or 3560. very need | sp-lox | Nokia CDMA | 1 | 12-30-2003 20:59 |
need pinouts for HF for dancal | mru | Various | 0 | 03-21-2003 11:29 |
