02-02-2008, 19:04 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if pinout on PCB is not working (which is very, very strane by the way) then i can advice you a easy method do search for needed pins in system connector. this method is based on measuring voltage on each phone pin (on powered on mobile) here is a link to tutorial: http:///vbb/attach...7&d=1187384324 |
02-03-2008, 14:45 | #12 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Batna Age: 43
Member: 85151 Status: Offline Thanks Meter: 30 | i try this method and with this methode i found many pinout but whit this connector can't now i found pinout and voltage of pin is correct but still phont not boot |
02-03-2008, 15:44 | #13 (permalink) |
No Life Poster Join Date: Nov 2007 Location: tunisia elmanar sfax
Member: 636518 Status: Offline Thanks Meter: 175 | untill no the only solution for you is the ''HK e BOX ''(china) with rx tx finder...he can find the rx and tx automaticly...i used it to find strange pinouts...... after that you can formatyour phone by infinity....it is the best...... we whate for the infinity rx/tx finder....good luck... |
help china pinout vertu ascent 2x7 | cupon | Infinity-Box | 4 | 06-20-2008 20:26 |
need pinout charger connector for e122 | batakari | NEC | 4 | 05-20-2008 19:11 |
Pinout N82 connector 6*2 | elvase | Chinese Models & Cloned Phones | 2 | 05-11-2008 12:30 |
hi need pinout n82 | samero85 | Infinity-Box | 8 | 03-14-2008 21:50 |
Need pinout t191 connector under battery for JTAG | MaxiGroup | Motorola ODM | 5 | 08-15-2003 10:36 |
