Old 10-26-2007, 17:31   #1 (permalink)
sagtel's Avatar
Member: 597666
Thanks Meter: 286
Need pinout for O3 818
need pinout for O3 818 connector_2x6_mini
cpu type: ARM_MT6205-ENSL-AJ05C
Old 10-26-2007, 17:49   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 10-29-2007, 09:28   #3 (permalink)
Moderate's Avatar
Member: 232566
Thanks Meter: 150
Hi brother i had the same Mobile but Different Name O3 V758.
Same hardware exact as yours and same connector same PCB.
here is the pinouts
GND --Anywhere on the PCB.
Rx --- 3
Tx --- 5
But one thing to notice is that i tried this at different speed but finally it worked at 115200.At higher speed it wasnt connecting at all.So make sure that use the aboe mentioned speed to work this pinouts.I am not sure it works for you cause it is china mobile but one thing is that same mobile and same hardware same Connector should work for you also.
Regards,
Moderate.
Old 10-29-2007, 10:59   #4 (permalink)
sagtel's Avatar
Member: 597666
Thanks Meter: 286
thank you moderate
pinout tested ok workink 1000%
Need help I need pinout for this chinese phone cayton_l Infinity-Box 9 12-03-2008 19:22
I need help. need pinout for 6060v RH-97 IkaMazini HWK 1 07-26-2008 07:22
need pinout for Nokia 3520 or 3560. very need sp-lox Nokia CDMA 1 12-30-2003 20:59
need pinouts for HF for dancal mru Various 0 03-21-2003 11:29
Page generated in 0.26110 seconds with 10 queries
