03-09-2010, 23:13 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: FomTekLAB Mexico-United States
Member: 645603 Status: Offline Thanks Meter: 89 | Need the Pinout of Pantech C180 and C320 |
03-10-2010, 21:51 | #7 (permalink) |
Member: 645603 Status: Offline Thanks Meter: 89 | Thanks to my Friend LAYNA who made that cable to test this phone.To unlock this phone need firts flash and than use Unlock Standard. COM4 [VCP2] selected module v3.24 Device: Pantech-C180 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:70FD:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: SIMC23_07A_PCB01_GPRS_MT6223_S00.C180_V01_01B05.BI N project-id: C180_V01.01B05, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Pantech-C180_SIMC23_07A_PCB01_GPRS_MT6223_S00.C180_V01_01B 05__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Pantech-C180_SIMC23_07A_PCB01_GPRS_MT6223_S00.C180_V01_01B 05__ffs_20100310-142929.B0E.bin flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 98000300000001:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 38 sec Remove/Install battery now ! |
The Following User Says Thank You to djkiddrick For This Useful Post: |
03-10-2010, 23:30 | #8 (permalink) |
Member: 645603 Status: Offline Thanks Meter: 89 | we only tester from mexico,i have 2 pantech duo(C810) here one dead other in good condition,but if YellowBoss want we can test what ever he want.regard |
09-10-2010, 20:26 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum |
need hlp for the pinouts of ztc zt6698 dead.. plz hlp | peter002 | Infinity-Box | 4 | 04-24-2008 15:18 |
how to find the pinout of first and second cpu of dual cpu phones | maximas007 | Infinity-Box | 3 | 03-20-2008 05:38 |
I need the pinout of cables v-spec | siscel | J.A.F. V-SPEC | 1 | 02-03-2008 06:26 |
Please I need to know the pinout of SPECIAL RJ45 of multi box | tsarkh | Chinese Cocktail | 3 | 01-30-2008 14:03 |
I need the pinout of Motorola T192, someone has it?Thanks | samark | Motorola Old Legacy (EMMI) | 0 | 01-26-2002 20:41 |
