03-29-2010, 09:52 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | spice s-545 no service ?????? module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #01 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #02 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #03 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #04 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #05 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #06 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #07 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #08 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #09 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0A in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0B in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0C in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0D in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0E in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #0F in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 detecting chip #01 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00380000 standard ffs/eeprom offset confirmed: 00380000 detecting ffs/eeprom size... ffs/eeprom size: 00080000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00380000-003FFFFF detecting ffs/eeprom structure pass 1... ...... detect standard ffs/eeprom location pass #1... ........... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... ................ ........... firmware version: GW20C_PCB01_GSM_MT6205B_DN.2_06.BIN2 detecting firmware build... ........... firmware build: ے`‚;2.06IACJ_GW20C_HW2007-08-2412-06 detecting product-id... ................ done detecting languages... ........ language parameters detected detected languages: En Hi Finished, time used: 38 sec Remove/Install battery now ! pl. help infinity team |
The Following User Says Thank You to omkarvitekar For This Useful Post: |
03-29-2010, 15:03 | #3 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | In which condition you get mobile ? ? Explain your problem clearly did you get no service after doing any operation with infinty ? Hardware faulty also creates same problem(network issue) Br Karan |
03-29-2010, 17:12 | #5 (permalink) | |
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Quote:
first time network fluctuate & hang i reset factory setting manully after that, this problem occured | |
03-29-2010, 18:32 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You can try to flash phone with repair eeprom file from support area and see results, but I think it's hardware problem: Can not make a call - Infinity-Box |
How to unlock spice s-545 ? | ..::Sunil::.. | Infinity-Box | 14 | 01-13-2014 08:57 |
spice S-545,s-404n ????? | vipimg | Infinity-Box | 6 | 11-07-2008 17:06 |
spice s-545 | karnataka | Infinity-Box | 1 | 11-17-2007 07:11 |
Badly Need Spice S-545 Pinout | ramesh_931 | Infinity-Box | 3 | 11-08-2007 11:30 |
spice s -545 not support | deecee | Infinity-Box | 1 | 10-30-2007 09:39 |
