11-03-2007, 15:40 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | $## Need Pinout for TREND T300 ##$ i need pinout for Trend T300 many thanks 1x8 Br Faisal_Computer Last edited by Faisal_Computer; 11-03-2007 at 15:49. |
11-06-2007, 19:55 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, 2 days gone. 1x8 pins connector. 8 - 1 (gnd) - 1 (charge) = 6 rest pins can be used as Rx/Tx. I think you can find pinout by yourseld faster than wait for reply. Please, don't forgte to post your found pinout here. Here is detailed instruction for you if you have lost it: Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
11-07-2007, 06:20 | #5 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | Brother many thanks for reply !! i do mostly all Things but can't get pinouts and Problem is Mobile Was Gone .. so that why i can't do any thing else and i am asking for pinout cause for next time if i got any TREND T300 i have pinouts hope you understand br Faisal_Computer |
11-07-2007, 11:23 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you have tried all connector pins but no luck this mens that Rx/Tx point should be located on PCB, so it was need to open phone and try to find RXD and TXD points directly at phone PCB. |
12-06-2007, 12:51 | #10 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Ok I got the OK phone in my Hands Processor is MT6228 Nand Problem is that Chinese Miracle not fully supports this CPU Only Safe Formatting Works on this CPU Full Formatting never helps . so Safe Formatting is OK But when i read FULL Flash COM4 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: read NAND flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 921600 Set baud Done Identification... reading... detecting structure... converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: HEDY28_06A_PCB04_GPRS_MT6228_S02.MAUI_06A_06_36_M7 8_VT_1_38.BIN ver. sw2: MAUI.06A.06.36.M78.VT.1.38 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok identification#1 structure: 2nd [standard] (or higher) generation reading... error: unexpected answer: warning: probably errors exist during flash read operation Finished, time used: 40 sec Remove/Install battery now ! I also Recieves many MT6228 CPU like ON OFF Problem keep restarting Software shows Full Formatting OK but phone still have problems & some phone i recieve of thsi CPU have SIM Restart Problem means After we SIM in Phone it restarts as it accepts SIM so this Phone can be 100% Ok by Safe Formatting so Safe formatting is OK & nothing else working Thanks Aamir Zia |
02-15-2008, 21:58 | #13 (permalink) |
Junior Member Join Date: Jan 2004 Location: lahore Age: 36
Member: 50103 Status: Offline Thanks Meter: 3 | hi guys.. sorry my question is not related to the topic.. but 1. can someone point me the way from where i can get all the flash files for TREND mobile phones? 2. does anyone know how can we modify those flash files? so we can replace the start-up logo of them and the default ringtones? because each time i flash trend phones with chinese flash.. i get chinese ringtones and videos in it.. i want to modify those files, to put ringtones and videos of my choice. please if some one can help me in it. thanks bbye |
02-15-2008, 22:36 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! best of all i would advice to find same phone with needed languages / pictures/ music and read out flash. later you can use it to flash your phones we dont have any soft to edit/add/remove them |
