03-10-2010, 13:57 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Bermuda Triangle
Member: 776382 Status: Offline Thanks Meter: 105 | Finally new alcatel v212 unlocked |
03-10-2010, 14:04 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock: 1. use "MModule" software v3.22 or newer 2. use "Write" button from software "Service" page and write original imei (from phone back label) 3. make "sp-unlock" |
03-10-2010, 14:39 | #3 (permalink) |
Member: 776382 Status: Offline Thanks Meter: 105 | thanks yellowboss but 1st i meant NEW CHIPPED alcatel V212 which we hav posted a lot of complaint about those phone which dont BOOT on infinity software and on the forum we see posted logs of those old alcatel v212 unlocked, SO REMEMBER THAT WE ON OUR MARKET HAVE A LOT OF NEW ALCATELS V212 STILL LOCKED and if you come up with solution let us know other YellowBoss your post too is WONDERFUL since a few days ago i tried to unlock alcatel 203 and it had boot errors. Will test then a post log if i get one. |
03-22-2010, 13:00 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | alcatel ot 708 unlocked succefully COM6 [VCP0] selected module v3.25 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:E603:A007 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.755BF 7B9.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_A8667CC5].rpl rom info detection finished device-id: 755BF7B9 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, C57C66A8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16CB27 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16CB27 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703723066 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_755BF7B9_A8667CC5_20 100322-124814.B0X.bin Finished, time used: 4 min 38 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to yahia ali For This Useful Post: |
Alcatel V212 unlocking problem. | baldev | Infinity-Box | 8 | 10-27-2010 23:26 |
NEW ALCATEL V212 CPU info | DOCTOR8 | Alcatel TCL Phones and New Models | 20 | 08-26-2010 16:17 |
NEW ALCATEL V212 Test result by multi-box | DOCTOR8 | Multi-Box | 12 | 04-25-2010 22:33 |
Alcatel V212 unlocked ........ | abdulwajid147 | Infinity-Box | 1 | 03-31-2009 15:06 |
alcatel v212 unlock fine by infinity 2day | stivubicco | Infinity-Box | 1 | 11-03-2008 15:59 |
