01-11-2009, 17:34 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, There are a lot of different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
01-17-2009, 19:04 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
01-18-2009, 18:30 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! usually phones do not restart without SIM card, so this code can be used. 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
n 95 8gb-chaina need pinuot | mahesh_patel361 | VE-PRO BOX | 6 | 09-24-2008 13:51 |
Plss help me.Need IMEI bluetooth D500 | ticoichip | SWIFT Platform | 0 | 03-14-2006 02:21 |
Need D500 Bluetooth ID?? | ~mr_Ten$ion~ | SWIFT Platform | 1 | 02-28-2006 06:27 |
help needed with bluetooth software | anush256 | Bluetooth-Software | 0 | 01-20-2006 19:17 |
Need a bluetooth dongle that supports hid proxy | Phantasm4489 | Bluetooth-Software | 6 | 04-15-2005 19:40 |
