Old 04-11-2009, 05:03   #1 (permalink)
Member: 133351
Thanks Meter: 20
need to remove phone lock code
Hi i need to remove a phone lock user code
but when i try format i get this error that flash chip is empty
what flash do i need to use to flash it good?
COM3 [VCP6] selected
module v2.80
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection disabled
Action: repair security area
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6205:8B00]...
CPU: MT6205
high speed boot On
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 01227E221A2201:FFFFFF00000000
flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
detecting chip #09 in region #00...
detecting chip #0A in region #00...
detecting chip #0B in region #00...
detecting chip #0C in region #00...
detecting chip #0D in region #00...
detecting chip #0E in region #00...
detecting chip #0F in region #00...
number of flash chip/regions detected: 10/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 00400000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detecting security area (code #2)...
security area (code #2) is absent
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
Finalization Done
Finished, time used: 51 sec
Remove/Install battery now !
thanks!
Old 04-12-2009, 18:45   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,456
Hello,
Is it single sim or dual sim phone ?
Old 04-14-2009, 20:50   #3 (permalink)
Member: 133351
Thanks Meter: 20
Hi there
thanks for the reply
i managed to read the user code by searching for second set of RX/TX pins as they are for the first sim
its a dual sim phone . it says TV-MOBILE N99i
the problem i have now its restarting
where can i download the flash and how do i flash it? its my first try to flash a chinese phone
any help would be greatly appreciated
thanks and best regards
SEWKAR
Old 04-15-2009, 06:13   #4 (permalink)
Member: 130995
1. read phone information
2. make full flash for emergency case (it's VERY important)
3. where to get files: in support area \flashfiles\ChineseMiracle
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
Old 04-19-2009, 22:09   #5 (permalink)
Member: 133351
Thanks Meter: 20
hi thanks for the reply
but how do i know exactly which file to flash into the phone?
br
SEWKAR
Old 04-20-2009, 05:28   #6 (permalink)
Member: 130995
Hello,
You do not need to flash phone. Just try to make "format ffs" as a first step.
Do not forget to make full flash backup before "format" operation for emergency case.
Old 04-20-2009, 08:37   #7 (permalink)
Member: 130995
@kawish
here is Infinity-Box support forum. If you have a problems with JAF please, post your questions in JAF support forum.
Your offtopic message was deleted.
How to remove phone lock code G810??? jham UST Pro II 19 10-04-2009 12:11
Is possible to remove Phone Lock Code on DB-2020 phone without Unlock RSA? Jazz Cruiser Suite 6 09-18-2008 01:01
All Pda Smartphone Pna Soft And Hard Reset, To Remove Phone Lock Code aikonmani GSM Mobile Links 1 07-06-2008 22:50
How to remove phone lock code on x70? sutiee Panasonic 9 04-21-2005 08:38
how to remove phone lock code on k508i jusluke Cruiser Suite 4 01-27-2005 09:42
Page generated in 0.32226 seconds with 8 queries
