need s404 spice cable any one in forum i need spice s404 unlocking working cable and if it is not available in market ,then any one who can tell me how to make its cable... i am first time making any cable so plz can any give me solution for makig cable step by step and unlocking it by video....it would be great for me and for other infinity customers who are newbie like me...:D |
how to make cable step by step hello! take any cable with RJ45 connector. make sure that pins 2,3, 8 is present. In my case this is colurs white, red, orange. http://www.infinity-box.com/download...j45picture.JPG Infinity box pinout is: 2 -TX 3 -RX 8- GND in our case this means that: TX is RED RX is WHITE GND is ORANGE now take Spice 404 pinout picture from our support area http://www.infinity-box.com/download...-S400_S404.jpg and connect wires according they colurs and should get this: http://www.infinity-box.com/download...c/404cable.JPG as you can see at the point where wires goes under battery i used thin wires, so they let battery to fit in. I am sure that select program from Shell manager set phone model and comport you will be able without Video. Then just push "Unlock" if anything needs explaned more- please ask, i will edit my posting |
I think it's amazing explaination for new commers how to make new cable.InfinityTeam is the best |
good work thnx sir for this useful post and great help ,sir u are giving way to new ones also with this they can also do better in unlocking bussiness.... Best regards. |
Thanks Thanks Sir, I have resd the handset successfully,I have used the RX ,Tx wrong. Thanks Again |
Hello! most common problem when cable is not working is TX, RX swap |
yes tested works well thanx |
Infinity.............. can you redirect me how can i recognize what cable is rx and what tx becouse in some cases rx is red in this case rx is white how can i recognize them thks in advice Br Formingus |
hello! easyest way is to check with multimeter |
Infinity tell me how a littel explanation how...... |
hello! put multimeter in resistance measuring mode. set one pin of multimeter to pin 2 of RJ45 connector. with other multimeter pin you check one by one all wires which comes out of cable. All pins will have no connection and only one will show 0 Ohm. This wire will be number 2 of RJ45. which means box TX wire. Same way you can find RX. |
tnks for extremly quick replay:p |
resistance measuring mode (See picture of Multimeter-where is?) and the other two are Rj45 and out wires of rj45 connector does i try to found in right way and about groud how can i find.. don't bore my friend i ask beacouse i don't have knowledge about those wires but with you help i think that i will learn. Then i will help others to learn and alleviate to you :) thks in Advice Br Formingus |
sorry i forgot attachments sorry for bad quality only 2.0mp |
hello! photo is not clear enought, but i will try. as i can see you need to put multimeter on black mark (8 o'clock if we compare with regular clock ring). it is marked with Diode symbol. Ground is pin 7 of RJ45. As i can on picture you count pins from a right side. From left to right. |
