Old 03-22-2007, 16:15   #1 (permalink)
Member: 205788
Sonork: 100.1573680
Thanks Meter: 369
Lightbulb need s404 spice cable
any one in forum i need spice s404 unlocking working cable and if it is not available in market ,then any one who can tell me how to make its cable...
i am first time making any cable so plz can any give me solution for makig cable step by step and unlocking it by video....it would be great for me and for other infinity customers who are newbie like me...
The Following 2 Users Say Thank You to surbir001 For This Useful Post:
Old 03-22-2007, 20:24   #2 (permalink)
Member: 148515
Thanks Meter: 16,149
how to make cable step by step
hello!
take any cable with RJ45 connector. make sure that pins 2,3, 8 is present.
In my case this is colurs white, red, orange.
Infinity box pinout is:
2 -TX
3 -RX
8- GND
in our case this means that:
TX is RED
RX is WHITE
GND is ORANGE
now take Spice 404 pinout picture from our support area
and connect wires according they colurs and should get this:
as you can see at the point where wires goes under battery i used thin wires,
so they let battery to fit in.
I am sure that select program from Shell manager
set phone model and comport you will be able without Video.
Then just push "Unlock"
if anything needs explaned more- please ask, i will edit my posting
The Following 17 Users Say Thank You to InfinityHelp For This Useful Post:
Old 03-22-2007, 20:52   #3 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
I think it's amazing explaination for new commers how to make new cable.InfinityTeam is the best
Old 03-23-2007, 09:00   #4 (permalink)
Member: 205788
Sonork: 100.1573680
Thanks Meter: 369
Lightbulb good work
thnx sir for this useful post and great help ,sir u are giving way to new ones also with this they can also do better in unlocking bussiness....
Best regards.
Old 03-24-2007, 08:07   #5 (permalink)
Member: 321523
Thanks Meter: 60
Thanks
Thanks Sir,
I have resd the handset successfully,I have used the RX ,Tx wrong.
Thanks Again
Old 03-24-2007, 08:44   #6 (permalink)
Member: 148515
Hello!
most common problem when cable is not working is TX, RX swap
Old 03-24-2007, 09:31   #7 (permalink)
Member: 101827
Thanks Meter: 23
yes tested works well
thanx
Old 04-14-2007, 18:08   #8 (permalink)
Member: 322417
Thanks Meter: 914
Post Infinity..............
can you redirect me how can i recognize what cable is rx and what tx
becouse in some cases rx is red in this case rx is white
how can i recognize them thks in advice
Br Formingus
Old 04-14-2007, 18:17   #9 (permalink)
Member: 148515
hello!
easyest way is to check with multimeter
Old 04-15-2007, 09:43   #10 (permalink)
Member: 322417
Thanks Meter: 914
Post
Infinity tell me how
a littel explanation how......
Old 04-15-2007, 10:28   #11 (permalink)
Member: 148515
hello!
put multimeter in resistance measuring mode.
set one pin of multimeter to pin 2 of RJ45 connector.
with other multimeter pin you check one by one all wires which comes out of cable. All pins will have no connection and only one will show 0 Ohm. This wire will be number 2 of RJ45. which means box TX wire. Same way you can find RX.
Old 04-15-2007, 10:39   #12 (permalink)
Member: 322417
Thanks Meter: 914
Wink
tnks for extremly quick replay
Old 04-15-2007, 11:05   #13 (permalink)
Member: 322417
Thanks Meter: 914
Talking
hello!
I put the attachments for better description (beacouse i am begginer it;s hard to understand)
resistance measuring mode (See picture of Multimeter-where is?)
and the other two are Rj45 and out wires of rj45 connector does i try to found in right way and about groud how can i find..
don't bore my friend i ask beacouse i don't have knowledge about those wires but with you help i think that i will learn. Then i will help others to learn and alleviate to you
thks in Advice
Br Formingus
Old 04-15-2007, 11:07   #14 (permalink)
Member: 322417
Thanks Meter: 914
Post
sorry i forgot attachments
sorry for bad quality only 2.0mp
Old 04-15-2007, 11:19   #15 (permalink)
Member: 148515
hello!
photo is not clear enought, but i will try.
as i can see you need to put multimeter on black mark (8 o'clock if we compare with regular clock ring). it is marked with Diode symbol. Ground is pin 7 of RJ45. As i can on picture you count pins from a right side. From left to right.
need solution spice c5300 [cdma] ranagaurav Various CDMA/TDMA Cell Phones 9 07-01-2012 09:24
need help spice s-710 ali_imran Infinity-Box 3 09-12-2009 12:32
Full flash backup need for spice s8-Urgent Plz help someone. rk_grover77 Infinity-Box 0 03-03-2008 05:33
Spice Cable S 500 Not Working. Cable Connection Is Wrong shahi Infinity-Box 4 01-19-2007 08:38
s 600 spice cable not working nilan Infinity-Box 1 12-27-2006 12:12
Page generated in 0.44883 seconds with 9 queries
