need sigmatel fxd T33i flash file. hello guys. i need sigma fxd T33i flash file for infinity box. (BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.T33+_TS70_TR IPLE_V010.BIN]_20090310-123253.B0M) thanks in advance. |
hello! what problem with phone? can not be solved by format FFS? please make full software backup before any operation (read full flash) |
T33i died after formatting. phone was locked.i take full flash backup with infity and reset phone. phone died after formatting. now when i flash with its backup, infinity shows write error.what can i do now ? thanks for quick reply. |
hello! need to see error log |
here is full process log with infinity box COM12 [Serial2] selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: write NOR flash security area recalculation disabled write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:CE03:0005 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #01 in region #00... flash: 98000300000000:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #02 in region #00... flash: 98000300000000:FFFFFF00000000 flash: Toshiba T 16Mb detecting chip #03 in region #00... flash: 98000300000000:FFFFFF00000000 flash: Toshiba T 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. ............................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. ............................................... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished Area: Firmware flash: 98000300000000:FFFFFF00000000 Write: Firmware error: error# 0000FFFF error: flash write error: 00000000:00002000 Write Fail Finished, time used: 153 sec Remove/Install battery now ! please guide me thanks.......... |
hello! you must be using old version CM. download newest |
need sigmatel fxd T33i flash file. |
have you tried to solve your problem by format FFS ? only after that try flashing. post your requered flash file version. it must be read in "read detailed information" mode |
i also have one fxd t33i which was working well but i have to format it with CM , but after formatting the set is dead .. is there any help for this fxd t33i .. |
ussualy program automaticly save eeprom backup. (if you did not disable this option) load this backup as eeprom and write back to your phone it must be restore to original state |
yesterday i was able to revive my phone from a file from infinity support area .. thanks |
