Old 03-10-2009, 09:26   #1 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 270
need sigmatel fxd T33i flash file.
hello guys.
i need sigma fxd T33i flash file for infinity box.
(BOWAY25_GEMINI_PCB01_GPRS_MT6225_S00.T33+_TS70_TR IPLE_V010.BIN]_20090310-123253.B0M)
thanks in advance.
The Following 2 Users Say Thank You to shuaib_kashish For This Useful Post:
Old 03-10-2009, 11:41   #2 (permalink)
Member: 148515
Thanks Meter: 16,160
hello!
what problem with phone? can not be solved by format FFS?
please make full software backup before any operation (read full flash)
Old 03-10-2009, 12:18   #3 (permalink)
Member: 405715
Thanks Meter: 270
T33i died after formatting.
phone was locked.i take full flash backup with infity and reset phone.
phone died after formatting.
now when i flash with its backup, infinity shows write error.what can i do now ?
thanks for quick reply.
Old 03-11-2009, 21:49   #4 (permalink)
Member: 148515
hello!
need to see error log
Old 03-15-2009, 12:50   #5 (permalink)
Member: 405715
Thanks Meter: 270
here is full process log with infinity box
COM12 [Serial2] selected
module v2.77
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection disabled
Action: write NOR flash
security area recalculation disabled
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:CE03:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000000:FFFFFF00000000
flash: Toshiba T 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
error: error# 0000FFFF
error: flash write error: 00000000:00002000
Write Fail
Finished, time used: 153 sec
Remove/Install battery now !
please guide me thanks..........
Old 03-15-2009, 22:44   #6 (permalink)
Member: 148515
hello!
you must be using old version CM.
download newest
Old 07-22-2009, 18:25   #7 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
Old 07-24-2009, 11:06   #8 (permalink)
Member: 148515
hello!
have you tried to solve your problem by format FFS ?
only after that try flashing.
post your requered flash file version.
it must be read in "read detailed information" mode
Old 09-11-2009, 03:56   #9 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 768
i also have one fxd t33i which was working well but i have to format it with CM , but after formatting the set is dead ..
is there any help for this fxd t33i ..
Old 09-11-2009, 20:13   #10 (permalink)
Member: 148515
hello!
ussualy program automaticly save eeprom backup.
(if you did not disable this option)
load this backup as eeprom and write back to your phone
it must be restore to original state
Old 09-12-2009, 05:04   #11 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 768
hello!
thanks sir for support ..
yesterday i was able to revive my phone from a file from infinity support area ..
thanks
The Following User Says Thank You to gsmsikar For This Useful Post:
need sigmatel fxd s30 flash file himanshu taldar Infinity-Box 2 03-09-2010 10:30
sigmatel fxd t33i flash file needed XpErTsGsM CPF-BOX Ⅱ 6 02-15-2010 14:05
need sigmatel fzd s89i flash file for infinity sr8787 Chinese Models & Cloned Phones 0 12-25-2009 08:14
sigmatel fxd T33i flash file XpErTsGsM Infinity-Box 1 10-26-2009 15:59
Page generated in 0.37305 seconds with 8 queries
