08-19-2009, 07:26 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: HP Mnla,Philippines Age: 38
Member: 247410 Status: Offline Thanks Meter: 161 | >> My/phone MS28 DUO PHONE CODE DONE << Code: ==== log: [8/18/2009 8:19:54 PM] ==== COM9 [VCP0] selected module v2.87 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8324:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E01C_PHILIPPINES_V7_02 Version: TINNO23C_08A_GEMINI_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35379803006267 connection Ok detecting structure #1... 0 3 4 7 8 9 13 14 15 16 19 20 23 24 25 29 30 31error: detection failed (18 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 104 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [8/18/2009 8:25:16 PM] ==== COM9 [VCP0] selected module v2.87 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8324:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E01C_PHILIPPINES_V7_02 Version: TINNO23C_08A_GEMINI_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35379803006267 connection Ok building list... done items to clear: 142 warning: wrong packet cs items cleared: 142 of 142 building list... done items remains: 0 Finished, time used: 27 sec Remove/Install battery now ! ==== log: [8/18/2009 8:26:48 PM] ==== COM9 [VCP0] selected module v2.87 Action: imei imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 358888888888886 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8324:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E01C_PHILIPPINES_V7_02 Version: TINNO23C_08A_GEMINI_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read verification... verification done: 35888888888888 Finished, time used: 21 sec Remove/Install battery now ! |
The Following 6 Users Say Thank You to jhepoy_org For This Useful Post: |
>> FOMA L705iX Unlocked Done << | jhepoy_org | VygisToolbox | 4 | 10-01-2013 08:42 |
>>> MYPhone T22 DUO lock code done and PINOUT HERE <<< | keaelite | Infinity-Box | 10 | 06-22-2009 19:22 |
unlock done << Pantech C300 >> in 7 Sec | Faisal_Computer | Infinity-Box | 2 | 01-07-2009 08:05 |
<< Asus J206 Phone Code Done W/ infinity >> | jhepoy_org | Infinity-Box | 3 | 08-21-2008 16:02 |
My/phone s22 duo phone lock problem | jhepoy_org | Infinity-Box | 7 | 03-11-2008 15:49 |
