Old 09-14-2015, 18:02   #1 (permalink)
Member: 1330570
Sonork: 100.1611533
Thanks Meter: 408
need some help >>>>>
Q mobile M90 after flash become logo hang and give some error during flash before flash handphone had some hang fault but worked
write file Logs:-
  Operation : Flash [ v1.30 ]
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004B3758564D4201EF3EDE777187
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D4201EF3EDE777187
[eMMC] : FLASH_EXT : 00400000/00080000
[eMMC] : FLASH_LEN : 0x00000001D2000000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : gionee82_cwet_kk , Storage : EMMC
Setting : AFF verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000880000-0x0000000000100000
Erase : 0x0000000002580000-0x00000001CEE00000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_gionee82_cwet_kk.bin
Preloader Sent , Init passed
PartCount : 0015
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : SPDATA
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:01:37
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Error! Something went wrong!
ErrCode : 0xD7D9
Done!
Elapsed: 00:02:01
Reconnect Power/Cable!
Old 09-15-2015, 02:54   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. At least - rehot eMMC. Then flash again.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.11486 seconds with 8 queries
