Old 05-02-2011, 15:54   #1 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Need some help from infinty
Set comes in low battery shut down problem.before any doing I read full flash backup and change MTK6223 from another broad now phone needs to flash it. During flashing I'm facing some errors please check log and tell me solution. backup is here. model Chinese nokia 1680
M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616_ _fullflash_20110501-141905.B0M
COM6 [Serial2] selected
module v3.30
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616_ _fullflash_20110501-141905.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:52A9:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is absent
startup code area #1 record #1 is damaged, recalculation required
rom info detection finished
device-id: B278F5DE
rom info ver: 05
sw version: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN
project-id: KAAM705DHZ_2.03.616, 32E24251
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
rpl file not found: C:\InfinityBox\ChineseMiracle\id.B278F5DE.[M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN_5142E232].rpl
rpl file not found: C:\InfinityBox\ChineseMiracle\id.B278F5DE._M705DHZ _PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616.BIN_514 2E232_.rpl
rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.B 278F5DE.[M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN_5142E232].rpl
rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.B 278F5DE._M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_ 2_03_616.BIN_5142E232_.rpl
warning: unknown firmware: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN_5142E232
Unknown firmware found (v.3.30, database date: 01.05.2011), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
detecting startup code area #2...
startup code area #2 is absent
You can flash phone now but can not finalize it,
in most cases phone CAN NOT power-on.
Do you want to continue anyway ?
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 1 min 19 sec
Remove/Install battery now !
Old 05-02-2011, 16:11   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please use following file:
https://rapidshare.com/files/4602578..._Id_Ar.B0M.bin
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 05-03-2011, 05:33   #3 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Thank you brother! problem solved
module v3.30
Action: write flash
write: Firmware
M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616_ 2009-06-16_16m_En_Fr_Id_Ar.B0M.bin
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
230400
Set baud Done
TCL-ID is absent
device-id: B278F5DE
rom info ver: 05
TCL-ID is absent
====> Write ...
normalized firmware detected: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_03_616. BIN
New firmware found (v.3.30, database date: 01.05.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
startup code area #1 calculation...
startup code area #1 fixed
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 1 min 1 sec
Old 05-03-2011, 06:01   #4 (permalink)
OTIENOJULIUS's Avatar
Member: 898387
Sonork: 1000.2
Thanks Meter: 103
Thanks for your instant response,I always like your quick responce
The Following User Says Thank You to OTIENOJULIUS For This Useful Post:
Old 05-03-2011, 20:49   #5 (permalink)
Member: 148515
I am here to help you, guys. Your problem is my problem
Old 05-07-2011, 05:11   #6 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
infinity is real responsible team thanks
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.21176 seconds with 9 queries
