Old 11-24-2009, 14:53   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
need spice d80 flash file
plz help me infinity i flash d80 flash file my set is white lite
any uplode this ver flash file
P67_PCB01_GPRS_MT6226M_S01.GD1_M802200SB_MP.BIN
i m waiting your great help
Old 11-24-2009, 15:11   #2 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
see log here all is ok but disply not show only white
COM50 [VCP1] selected
module v3.00
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6219:8B02:8B01]...
CPU: MT6219
high speed boot On
detected CPU: MT6226MA
chip: 0031:C09F:57FF
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:2AEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info protocol ver: 04
ver. sw 1: P67_PCB01_GPRS_MT6226M_S01.GD1_M741300SB_MP.BIN
ver. sw 2: GD1.M741300SB.MP, 00000000
address offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: P67_PCB01_GPRS_MT6226M_S01.GD1_M741300SB_MP__ffs.. .
file saved: C:\Program Files\InfinityBox\ChineseMiracle\P67_PCB01_GPRS_MT 6226M_S01.GD1_M741300SB_MP__ffs_20091124-203613.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 174 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 11-24-2009, 19:36   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
If you have problem with LCD after flashing this means that you need to use another firmware for this phone.
Do you have full flash backup from good working phone with P67_PCB01_GPRS_MT6226M_S01.GD1_M802200SB_MP firmware ?
Old 11-25-2009, 03:39   #4 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
thanks for reply
no i have no this firmwer so i reqwest plz uplode this firmwer
for your kindly help
Old 11-25-2009, 05:39   #5 (permalink)
Member: 130995
Originally Posted by ranagaurav View Post
thanks for reply
Hello,
If required file can not be found in support area (please use "search" function in support area first)
it will be good if somebody can read full flash from the same good working phone and send
full flash backup to support@infinity-box.biz so we will be able to prepare and upload
good working files in support area for all users.
Here is an instruction how to make "search" in support area: One Method for Find Flash File in Infinity Support Site
Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-25-2009, 16:47   #6 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
yes i try this methed but i cant found this ver so i serch maney time but i cant this ver flash file
Old 06-15-2011, 17:02   #7 (permalink)
Member: 513795
Sonork: 100.1605240
Spice D80 flash file backup
Originally Posted by InfinitySupport View Post
Hello,
Here is an instruction how to make "search" in support area: One Method for Find Flash File in Infinity Support Site - GSM-Forum
I have spice D80 working gpgdragon flash backup.can convert it into infinity supporting format ?,if want i will upload it.
need spice d80 flash file ranagaurav CPF-Dongle 0 11-25-2009 06:32
Spice D80 Flash File Need ranagaurav Chinese Models & Cloned Phones 1 11-25-2009 03:41
need spice s600n flash file very urjent pls Punit Kumar Infinity-Box 14 11-10-2009 15:40
Spice D80 Flash File Need .:TithiMobile:. Chinese Models & Cloned Phones 1 07-01-2009 10:57
need spice s415 flash file amanhalwara ET-BoX 0 04-11-2009 10:09
Page generated in 2.73030 seconds with 11 queries
