Old 10-19-2008, 03:26   #1 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
need support for this - e tel v118
lot of e tel phones available here,
here is log,
COM17 [VSerial0] selected
module v2.64
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:AA03:0004
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: E:\mobile\infinity box\InfinityBox\ChineseMiracle\backup_security\id. 54A9B51D.[M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN_42DA72A0].rpl
New firmware detected (2.64) :
- make "Read full flash" operation
- send "system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 54A9B51D
identification#1 protocol ver: 04
ver. sw1: M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN
ver. sw2: M3118_FM_G118_ETEL_V1.0, 5F8D25BD
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: flash[M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN]...
file saved: E:\mobile\infinity box\InfinityBox\ChineseMiracle\backup flash\flash[M3118_PCB01_GPRS_MT6225_S00.M3118_FM_G118_ETEL_V1_ 0.BIN]_20081019-063506.B0M.bin
file saved: E:\mobile\infinity box\InfinityBox\ChineseMiracle\backup_security\sys tem_log_54A9B51D_M3118_PCB01_GPRS_MT6225_S00.M3118 _FM_G118_ETEL_V1_0.BIN_42DA72A0_20081019-063533.B0X.bin
Finished, time used: 693 sec
Remove/Install battery now !
Action: read information
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6225, E03
Hardware version: M3109P_K5L_V10
Software version: M3118_FM_G118_ETEL_V
Software date: 2006.06.14
Barcode: MT012345678901234567
imei: 359446015066022
Finished, time used: 33 sec
Power off phone now !
safe format success
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [10/19/2008 6:38:03 AM] ====
module v2.64
Action: reset settings
19200 autodetect
CPU: MT6225
Connecting, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: M3118_FM_G118_ETEL_V1.0
Version: M3109P_K5L_V10
detecting structure #2...
0 done
44 byte(s) read
connection Ok
building list...
done
items to clear: 145
145 of 145 items cleared
warning: wrong packet cs
building list...
done
0 items remains
Finished, time used: 29 sec
here is full backup,
http://rapidshare.com/files/15537134...063506.B0M.bin
br.
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 20:38
hack3r2k,interested with TRACFONE & NET10 = LG & Samsung, We need support for this mymiela0419 FuriousGold 2 01-05-2010 10:11
---i need support for this model-- :::ANSWERED::: magico459 PolarBox 3 1 01-20-2009 00:19
Need flash for QTEK 9100, need better support for this solution gsmnice JAFWM 0 05-04-2006 17:26
Page generated in 0.15395 seconds with 9 queries
