08-13-2009, 08:23 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Need Spice S585 on Support... I Will Have this set for Few Hours Only... I Need This Model on Support... Processor Type & Pinout... software version: 1.19 cable type: 2x5 (L10C) platform: PMB: Infineon e-gold searching adapter at COM3... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold: A0 result: Rx:3 Tx:5 time required: 6 sec Trying to Power-On... Power On ! I Tried Read it by selecting LG KG288 model, It gives following reads. COM3 [VCP0] selected module v1.68 Device: LG-KG288 Checking data, wait... Action: read flash Boot ... Press and HOLD Power button now ! e-gold: A0 loading... error: can't run preloader: boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Failed Finished, time used: 13 sec Remove/Install battery now ! What Next can i Do?? Thanks |
08-13-2009, 08:58 | #2 (permalink) |
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | OK Got that Set Readed.... ----------------------------------------------------------------------- COM3 [VCP0] selected module v1.68 Device: J-Max-JM5700 Checking data, wait... Action: read flash Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 0001:0110 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\J-Max-JM5700_eeprom-static_20090813-125502.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\J-Max-JM5700_eeprom-security_20090813-125502.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\J-Max-JM5700_eeprom-complete_20090813-125508.B1E.bin backup critical area Done Check memory ... reading flash... file saved: C:\Program Files\InfinityBox\Pana01\Spice_S585_FullFlash_J-Max-JM5700_flash_20090813-130036.B1X.bin completed Finished, time used: 403 sec Remove/Install battery now ! ------------------------------------------------------- The Set is Hanged on "Test Poweron!" , On LCD, I Tried Resetting it.... But Even After resetting, The Set Remains On Same Situation.... What can Be done Next?? |
08-13-2009, 18:34 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
08-15-2009, 21:49 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Shubhanshu~ Please, send full flash backup to [email protected] so we will be able to check it. |
10-05-2009, 08:48 | #6 (permalink) |
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Still Waiting To see this handset on Support... Anybody got working Set in Hand, Please Read it & Send Flash Backup to support.. Thanks in Advance.. |
01-12-2019, 22:06 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
spice s585 charging connector problem | gsmsikar | Infinity-Box | 14 | 05-13-2009 09:42 |
spice s585 support | omkarvitekar | Infinity-Box | 2 | 04-27-2009 07:50 |
spice s585 charging connector problem | agaalias | Spice | 0 | 10-15-2008 11:48 |
Spice s585 | gsmsikar | Infinity-Box | 1 | 05-14-2008 20:35 |
we need newest firmware on support for arabic like E200 | tsarkh | NSPRO | 8 | 08-19-2007 19:18 |
