12-28-2008, 16:40 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | If you don't know the original firmware version of your phone then its too hard to find the desired flashfile from Chinese phone. You didn't wrote your firmware name, due to this reason till now no response from Supporters and other members. So if you really need help then plz tell us the original firmware version of your phone. Best Regards! yawarniazi |
12-29-2008, 01:47 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! here is example how to perform flash file search by yourself, without waiting someone's help http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
12-30-2008, 06:25 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | here is now format log COM16 [VCP0] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot enabled detected CPU: MT6226MA chip: 0031:3E410D8 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98004900000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 98004900000001:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20081229-232132.B0E.bin flash: 98004900000001:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000001:FFFFFF00000000 Finalization Done Finished, time used: 147 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
12-30-2008, 18:37 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! this is log from phone with fully erased flash. you might be made "erase whole flash" operation earlyer. now go to chinese miracle folder and open with any text editor file named "operation.log" scrool it up from end and look log records. find very first operation with this phone. Hopefuly there you will see version name. P.S. log contain time/date stamps, if you remmeber date/time when you first time connected phone- this will help you easyer to find needed part |
01-07-2009, 06:22 | #8 (permalink) |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | yesterday i am read and efrom file from another good working sprint p50.then flash format and repair security area also ok .but still is set dead . what is the next solution ? |
01-07-2009, 19:02 | #9 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hui, Post here operation log when you flash dead phone with good backup file. also send good backup file to [email protected] |
need sprint s60 flash file | unlock & flash | Infinity-Box | 16 | 09-07-2010 14:24 |
need sprint s80 flash file | sharif_tell | Chinese Models & Cloned Phones | 6 | 03-21-2010 15:05 |
need sprint s60 flash file pls help | gsm_bds | SpiderMan | 1 | 08-15-2009 10:51 |
i need sprint s80 flash file | mithon | CPF-BOX Ⅱ | 1 | 05-30-2009 07:52 |
i need sprint s60 flash file | mithon | Chinese Models & Cloned Phones | 3 | 04-24-2009 18:40 |
