06-21-2007, 05:08 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 170684 Status: Offline Thanks Meter: 19 | Fiy Sl400m Dead!!!!!! my sl400m dead affter flash with infinity, before it was hanging complant with&without sim. COM5 selected Device: Fly SL400m Checking data, wait... advanced flash detection active Action: Flash write Write: Firmware Skip: Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6217:8A00]... Release Power button now ! Boot Done Initialize... detecting chip[00] in region[00]... flash: 98004900000002 flash: FFFFFF00000000 flash: AMD/Fujitsu std [0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... flash: 98004900000002 flash: FFFFFF00000000 reading [eeprom]... file saved: backup_eeprom_20070620-192423.B0E.bin Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... Area: Firmware flash: 98004900000002 flash: FFFFFF00000000 Write: Firmware flash: 98004900000002 flash: FFFFFF00000000 Write: Firmware Write Done Finished, time used: 1197 sec Remove/Install battery now ! |
06-21-2007, 11:59 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @harisha g h to get fast answer you must write your question in correct thread. what to do: download latest MModule from support area and flash phone again. if phone can't power-on after flash: change state of "advanced chip detection" box in settings (enable or disable it) and flash phone again. finally phone will be alive. also make "format ffs". @-luigi- probably it's possible to support this phone. tell me phone CPU name and bottom connector description and we will see what to do |
06-22-2007, 03:31 | #5 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 39
Member: 138583 Status: Offline Thanks Meter: 120 | Hi. Thanks for the answer. This is the info that comes with the phone: MODELO:EZ700 FCC ID: RVE2EZ700 0609 Intel IMEI: 351718-01-0XXXXX-X ENSAMBLADO EN MEXICO CON COMPONENTES EXTRANJEROS <---- Maked in Mexico with components from other countries, maybe this is a knowed phone, but with another name just for be insamble in another country... About connection, I juts see one, the conection of the headphones at the right side, also heres a camera button and infrared port on same side. Seems that the headphone connection is the same of the headphone... Thanks for the fast answer... |
11-08-2007, 03:26 | #10 (permalink) | |
You have a chance to unlock your phone: Question: I have new phone model and I want to see this model supported by Infinity-Box. What to do ? Answer: 1. open phone, find CPU chip and Flash chip 2. send e-mail to [email protected] with the next info: 2.1. CPU chip name 2.2. Flash chip name 2.3. phone bottom connector type (photo, if available) 2.4. Gnd, Charge, +Battery pins location on phone connector 2.5. full text from phone back label (label under battery) 2.6. phone photo (or link to phone photo) 2.7. is it sp-locked or simfree phone 2.8. is it exist original data/com/usb cable in phone package 2.9. is it exist CD with original drivers in phone package 2.10. estimated phone price 2.11. any additional information We will check your information and will tell you is it possible to make support for this model or not. | |
03-13-2008, 15:24 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @luzer Please, check this instruction: http://www./showpo...5&postcount=10 |
05-19-2008, 22:06 | #13 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Americas Age: 54
Member: 71052 Status: Offline Thanks Meter: 0 | I have news about this model SKYZEN EZ700 This model really have MT6226 inside Pinout Rx:9 Tx:2 found using Pin Finder This is the log for PIN FINDER: Code: software version: 1.09 cable type: 2x7 (L14A) platform: MT6205, MT6217-MT6228 searching adapter at COM3... adapter found, version: 2000 pins: 14, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6226 result: Rx:9 Tx:2 time required: 48 sec Power On ! |
Hello¡¡ i need help for skyzen 700 thanks | UL15E5 | Infinity-Box | 1 | 01-13-2009 18:25 |
@ Supporter !! == NEED Support for Sendo == | Faisal_Computer | Infinity-Box | 2 | 09-05-2007 07:52 |
@Support Team, need support for D900i IMEI change. | The SAINT® | UST Pro II | 4 | 06-04-2007 13:42 |
Need Support for UFS3 | movilquick | UFS2 + UFS3-Tornadoflasher | 2 | 09-30-2004 18:37 |
We Need Support for making the E700 Better | ThaDon | SYSOL Platform | 0 | 12-09-2003 01:48 |
