10-18-2008, 14:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | need tv mobile rx tx............... need help very argently....... dual sim dual cpu .main cpu is 6205 and another is 6226 cable type L12c |
10-18-2008, 21:24 | #4 (permalink) |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | I have infinity pinfinder.Pinfinder detect it ok.But when i trying to format,the formating time reading eep it goes stop at 20% and phone automaticly power on. then error commands comming. |
10-23-2008, 13:59 | #6 (permalink) |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | pin pinder log software version: 1.14 cable type: 1x12 (L12C) platform: MT: MT62xx (autodetect) searching adapter at COM15... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6205 result: Rx:8 Tx:7 time required: 44 sec Power On ! |
10-23-2008, 14:00 | #7 (permalink) |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | COM15 [VCP0] selected module v2.64 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN ver. sw2: MAUI.06B.W07.20.MP.V7, 00000000 ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 003C0000 flash: 01227E221A2201:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 003C0000 detecting eeprom/ffs size... eeprom/ffs size: 00040000 ffs chip: 00 eeprom/ffs area: 00000000:003C0000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]... warning: wrong data size at 0x003C7C00, retry... warning: wrong data size at 0x003C7C00, retry... warning: wrong data size at 0x003C7C00, retry... warning: wrong data size at 0x003C7C00, retry... warning: wrong data size at 0x003C7C00, retry... warning: wrong data size at 0x003C7C00, retry... warning: wrong data size at 0x003C7C00, retry... warning: wrong data size at 0x003C7C00, retry... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN]_20081023-185156.B0E.bin error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request Finalization Fail Finished, time used: 83 sec Remove/Install battery now ! |
10-23-2008, 22:21 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! yes, you working with CPU6205, which is slave in this phone. please after you find this pinout, go to pinfinder advanced settings and disable this pins in search. repeat search procedure, you will find first MCU pinout. Make format |
All china mobile RX TX Here | rashel.com | Infinity-Box | 33 | 05-22-2014 14:47 |
need help in rx tx | Hamidshah07 | Infinity-Box | 1 | 07-15-2009 20:07 |
need bleu 250x Rx Tx | sanku | Infinity-Box | 3 | 01-06-2009 10:06 |
How Can I Creat Cable For Et-box Chaina Mobile Rx Tx | mahesh_patel361 | ET-BoX | 5 | 02-10-2008 08:31 |
need slaver box rx-tx | ><the mad>< | powerflasher | 0 | 11-08-2007 05:38 |
