need unbrick LG K371 I killed this phone by downgrading it from 11n to 10b Now, phone is stuck at 9008 mode. I cant access it using CM2QLM, looks like Loaders issue... and LGS only accepts connections using Download Mode (which I cant access) I have a backup of the original Firmware before the brick, Read with LGS MSM8909__LG-K371__K37111n__V11n__AOSv6.0__LGK371AT-00-V11n-ATT-US-SEP-29-2016-ARB01+0 Is there any way to unbrick the phone ? @JayDi |
i have same proble you can upload you firmware for make test by emmc |
very hard for me to upload big files. I dont have cheap fast line. |
ok bro can upload boot for try repair by isp thanks for you help |
Help me Unbrick LG K371 [Answered] - GSM-Forum PM me email address to send you boot.img (is this what you mean?) |
team we are very happy if u add 9008 port flash then no tool can beat infinity |
Go to driver manager and under the 9008 port, right click and update driver with emergency download driver found in cm2qlm/drivers/manual inst xp founder. Install every things there and how you can connect with cm2qlm loader. If help with click thanks bottom |
1 Attachment(s) Quote:
as I said, no Internal CM2QLM Loaders support this LG phone. not a driver issue. I said 9008 mode because it is the mode everyone knows... but it is in care suite emergency mode drivers |
OK try with hua tool Envoyé de mon SM-J7008 en utilisant Tapatalk |
Post QLM logs first. |
Code: Operation : Identify [ v1.15 ] |
try this pinout if you have emmc /jtag box tool http://forum.gsmhosting.com/vbb/f672...esult-2279836/ and heres the emmc configuration http://forum.gsmhosting.com/vbb/f664...flash-2231175/ dont solder vcc and vccq from adapter, instead use power supply, set to 3.8v and plug in the charger, make sure the isp adapter is also has 5v supply from pc usb port for cmd pull up, |
never replied to Logs posted. I ask, beacuse I keep receiving this model with v1.1n, impossible to flash |
