11-16-2017, 02:23 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | need unbrick LG K371 Now, phone is stuck at 9008 mode. I cant access it using CM2QLM, looks like Loaders issue... and LGS only accepts connections using Download Mode (which I cant access) I have a backup of the original Firmware before the brick, Read with LGS MSM8909__LG-K371__K37111n__V11n__AOSv6.0__LGK371AT-00-V11n-ATT-US-SEP-29-2016-ARB01+0 Is there any way to unbrick the phone ? @JayDi |
The Following User Says Thank You to yurais For This Useful Post: |
11-16-2017, 07:32 | #5 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | read here Help me Unbrick LG K371 [Answered] - GSM-Forum PM me email address to send you boot.img (is this what you mean?) |
11-16-2017, 15:43 | #7 (permalink) |
Freak Poster Join Date: Aug 2006 Location: gabon, oyem
Member: 327704 Status: Offline Thanks Meter: 84 | Go to driver manager and under the 9008 port, right click and update driver with emergency download driver found in cm2qlm/drivers/manual inst xp founder. Install every things there and how you can connect with cm2qlm loader. If help with click thanks bottom |
11-16-2017, 16:18 | #8 (permalink) | |
Member: 220595 Status: Offline Thanks Meter: 355 | Quote:
as I said, no Internal CM2QLM Loaders support this LG phone. not a driver issue. I said 9008 mode because it is the mode everyone knows... but it is in care suite emergency mode drivers | |
11-16-2017, 23:09 | #10 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Post QLM logs first. | ||
11-17-2017, 06:30 | #11 (permalink) | |
Code: Operation : Identify [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 08577957 ID_BLOCK_I : 009600E1 ID_BLOCK_E : 00310000 ID_BLOCK_L : 151F5739FF4CAA9D37B71F4B373FD853 ID_BLOCK_L : 7467FCF30F06A7EA06399936045A0047 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! | |
12-07-2017, 02:18 | #12 (permalink) |
Freak Poster Join Date: Jun 2011 Location: ph
Member: 1593041 Status: Offline Sonork: jmclamor Thanks Meter: 21 | try this pinout if you have emmc /jtag box tool http://forum.gsmhosting.com/vbb/f672...esult-2279836/ and heres the emmc configuration http://forum.gsmhosting.com/vbb/f664...flash-2231175/ dont solder vcc and vccq from adapter, instead use power supply, set to 3.8v and plug in the charger, make sure the isp adapter is also has 5v supply from pc usb port for cmd pull up, |
