Old 03-03-2016, 14:24   #1 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 179
Need Update for New Flash ID's
I am not sure about this idea. Because I don't have 100% idea about mean of flash id. Whatever I found too much phones as like this... I cannot read or flash. Because look like its not support. So please working on it and If you have explanation about this error give me it here...
Card found : S/N : xxxxxxxx , v0130
Chinese Miracle II [MTK module] v 1.41
Operation : Check / Read Info [ v1.41 ]
Wait for phone...
Phone found! [ 21 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 002C00BC009000550056000000000000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0090 , [Micron] MT29C4G96MAZAPCJA_5IT
[NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2
DEV RID : B09481CB68127FB90B28D03B5D983033
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:00:08
Reconnect Power/Cable!
Old 03-03-2016, 14:29   #2 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 179
Micromax D200 also same
Wait for phone...
Phone found! [ 21 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 00AD00BC00900055005600AD00BC0000
[NAND] : FLASH_VEN : 0x00A3 , [Hynix] H9TA4GH2GDMCPR
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC
[NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2
DEV RID : 6A352475C1846D3A35C80861E33D91E9
EXT RAM : 0x20000000
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:12
Another one also here.... I couldn't note that model
Wait for phone...
Phone found! [ 21 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
NAND Flash : 009800BC009000660076001500010000
[NAND] : FLASH_VEN : 0x0096 , [TOSHIBA] TYBC0A111557KC
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1
DEV RID : B2B9537AB5BC97E8C004E2D3EC4A1D31
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:09
Old 03-04-2016, 07:02   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,655
There is Universal way with NAND settings, as software advise you in log.
Also there is "Nand Ext" mode with Factory FW reading, which allow make FW in 90% cases even with problem phones, after you can use FW for further repair/service operations.
Page generated in 0.22671 seconds with 7 queries
