09-22-2015, 12:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Inside Universe
Member: 442808 Status: Offline Thanks Meter: 195 | Need Urgent Help with Lava Flair P1 with Pattern lock Code: Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:28 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Unknown structure detected! Something went wrong :( If phone work normally - send report to support! Elapsed: 00:00:42 Reconnect Power/Cable! |
09-22-2015, 12:35 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Select SC7715 eMMC and try again. Also in few cases you may need to select original pac file- http://forum.gsmhosting.com/vbb/f296...l#post11245128 Br. |
09-22-2015, 14:11 | #5 (permalink) |
Member: 442808 Status: Offline Thanks Meter: 195 | Ok Done like Knife cutting Butter Code: Loading : Lava_Flair_P1_S012_20150612.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7715_UMS PacVersion : Lava_Flair_P1_S012_20150612 FastCheck : 0x21230D05 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7715_modem.bin File : DSP_DM_G2.bin File : SC8800G_sc7715_wcn_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7715.xml Load Ok! Code: Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Flair_P1 Model Brand : Lava Model Device: Flair_P1 AndrVersion : 4.4.2 BaseBand CPU: SCX15_SP7715EA CompileDate : 1434102426 Project Ver : Lava_Flair_P1_S012_20150612 Model Ext : Flair P1 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:11 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 73 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 357896412 Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to situ_saraf For This Useful Post: |
