Old 12-22-2005, 10:22   #1 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
Need URGENT help with X700 unlock
Followed the Steps as outlined in documentation.
With X70 cable , I got this result.
Testing COM1 at 115200...
Boot...
Press Power button now !
Checking...
Boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
FLASH ID: 0089:8862
Connecting Done
Check free space...
Flash chip supported
In progress[EEP02]...
Loading data...
Data loaded
Check free space Done
Write...
Erasing: EEPROM
Writing: EEPROM
Verifying...
Verify result: 01AF
Done
Write Done
Finished
Remove/Install battery now !
Time used: 48 sec
When I turn on the phone I see
Panasonic
TAM
USB InitialState : 0
When I connect original usb cable to the PC nothing happens. it does not ask for drivers.
I am now stuck like this with customers phone. please help fast.
Old 12-22-2005, 10:50   #2 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
I am using Win 2000
When I look in the device Manager I see the new device as "USB Device" with it marked !. I click on update drivers and point it to the X700 drivers folder. it does not detect this driver. but it detects this driver D:Winnt//inf/usb.inf. I temp rename usb.inf to usb.bakinf and search for drivers again and point it to the X700 location but all it says is "Windows is unable to locate a driver for this device"...
What must I do ?. need help fast
Old 12-22-2005, 11:09   #3 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
Phone cannot now power off by pressing the power key.... should i REMOVE THE BATTERY ? is there any risk in leaving in in TEST MODE for too long ?
Old 12-22-2005, 15:57   #4 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
I have to be b u l l s h i t t i n g the customer as to the status of his phone.
need a solution fast.
Old 12-22-2005, 15:57   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
There is no risk to remove battery.
If you try to power on phone after removing battery your phone will start in Test mode again. To make phone back to ordinary power-on you need to make "Test-Mode Off".
As about drivers: could you try it on WinXP ?
Old 12-22-2005, 15:59   #6 (permalink)
Member: 130995
Also you can try to delete this unknown device from Device Manager. In this case win can try to detect device again.
Old 12-22-2005, 17:04   #7 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
In your instructions, it says that it should be on the screen
Panasonic
TAM
but on my screen it says
Panasonic
TAM
does that make a difference ?
Old 12-22-2005, 17:18   #8 (permalink)
Member: 130995
Pls, check X700 unlock instruction:
Old 12-22-2005, 17:38   #9 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
How cam I expect to see that result.
I am stuck at step 9
9. Connect X700 USB cable. PC ask for drivers.
PC does not ask for drivers.
on my screen is
Panasonic
TAM
When the USB cable is inserted it just detects it as a unknown USB device. when the cable is removed it is removed from the system. it does not take the X700 drivers when trying to upgrade drivers for this unknown device.
Old 12-22-2005, 17:46   #10 (permalink)
Member: 130995
Can you try to delete this unknown device from Device Manager. In this case Win can try to detect device again.
Can you try it on WinXP ?
Check phone connector. Maybe bottom connector contacts dirty and bad contact ?
Is it the same X700 with LCD problem ?
Old 12-22-2005, 21:17   #11 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
no. it is not the same phone with LCD problem ( I got the original cable from phone with LCD Problem)
Will try on Win XP later...
the battery is now dead...can it be charged while in TEST MODE ?
Old 12-22-2005, 21:39   #12 (permalink)
Member: 130995
Yes, it can be charged in test-mode.
Old 12-22-2005, 23:42   #13 (permalink)
Member: 14607
Thanks Meter: 10
plug in USB cable THEN power on the phone ,its will ask for driver this way. i had this problem and fixed this way.
hope this will help.
br
ktv
Old 12-23-2005, 12:48   #14 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
you are 100 % correct...
br
ktv
Thanks.. it asked for drivers.
cable have to attach to computer..then power on phone... if attach to phone then attach to computer will not work...Infinity should include this note in future documentation
Phone battery has now gone dead.. it will not charge, even though the charging light is on.. will now have to seek another customer and charge in another phone and then try to finish the unlock.
Old 12-23-2005, 17:59   #15 (permalink)
tical's Avatar
Member: 43802
Thanks Meter: 36
The unlock process went through OK.. but now phone asks for lock code ..
What is the Default Lock code ?... Tried 0000 and 1234 but no luck...
is there any software that can get the lock code ?
need some help with x700 karczi Samsung Flashers, Software, Firmware. 4 07-17-2007 06:06
need urgent help with L6 problem unlock bacau Smart-Clip 8 07-03-2006 13:09
need urgent help with 802sh unlock falak Cruiser Suite 3 10-25-2005 10:15
Need urgent help with my Griffin Box... byteforce Griffin 3 07-17-2004 16:38
Need Urgent Help With Unlock Motorola V66 IceKiller ZLIN Motorola P2k 10 11-18-2002 20:58
Page generated in 0.19629 seconds with 9 queries
