Old 02-11-2011, 09:27   #1 (permalink)
Member: 430612
Thanks Meter: 301
china e71 dead after fomat
COM9 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7503:0007
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\backup_security\i d.99122F4A.[PUYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_F2.BIN_457F7661].rpl
New firmware found (v.3.26, database date: 13.01.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: 99122F4A
rom info ver: 04
sw version: PUYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_F2.BIN
project-id: MAUI.GEMINI.W08.12.F2, 61767F45
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: PUYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_F2__ffs...
file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\PUYANG25_GEMINI_P CB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12_F2__ffs_20 110211-102116.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\backup_security\P UYANG25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W 08_12_F2__system_log_99122F4A_457F7661_20110211-102140.B0X.bin
Finished, time used: 5 min 8 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
phone was restarting before fomat and now phone is dead
Old 02-12-2011, 12:01   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Please, tell me, what was the problem with phone when you have got it in your hands.
Is it was completely dead phone ?
Old 02-13-2011, 08:41   #3 (permalink)
Member: 430612
Thanks Meter: 301
it was on and off ........
Old 02-13-2011, 19:53   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please do following:
load this file as EEPROM:
write back to phone. this will bring it to Restart condition again.
after that try Format FFS, but "SAFE" mode
Old 02-14-2011, 03:53   #5 (permalink)
Member: 1178397
Thanks Meter: 6
e-71 on/off
e-71 on/off it is hardware prob
1-back site of pcb clean up dry it
2-revole cpu
Old 02-14-2011, 05:48   #6 (permalink)
Member: 430612
Thanks Meter: 301
on my laptop it show that file is saved but when i check on chinese miracle folder i dnt find any saved files
5110 v 6.0 after unlocking problem with net cole Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-10-2001 16:11
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 22:24
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
"Menu 11"? after Net monitor Pyron Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-09-1999 10:07
Page generated in 0.21800 seconds with 9 queries
