03-15-2016, 09:12 | #1 (permalink) |
Insane Poster Join Date: Jan 2009
Member: 954240 Status: Offline Thanks Meter: 7 | Activating a problem some time ago had this Please help me as well i active cm2 and hua in my best dongle cm2 working fine but hua active not work my info --------------- PC HWID: 143F5576D4E9CFF9A5646C92722A5164 Box/Dongle searching... Box/Dongle found: [BEST] Card-Reader: FT SCR2000 0 HWID: 0004528301171292 Box/Dongle Serial No (S/N): XXXXXXXX Firmware version: 0122.02 "UK edition" status: Off Last launched Application: 0030 v.0140 Active modules: - 00: inf v.0130 - 03: [BEST] v.0122 - 0E: hua Online Service Account: Infinity-Box - Online Service I test 2.0.1 2.0.2 2.1.5 2.1.8 All same theis error is (( Run-time error '9': Subscript out of range )) Please, I want a solution to the problem And has the following methods experiment did not succeed in the solution How to Fix HUA conflict with gcprokey installer? read here if have smart card not found after activation on infinity(FINAL SOLUTION) And all existing solutions forum did not work Please help me |
03-15-2016, 10:37 | #3 (permalink) | |
Member: 954240 Status: Offline Thanks Meter: 7 | Quote:
tisting on windows xp 32 bit windows 7 32 and 64 bit Also it has experience on another computer The result The problem did not spill the beans Comes the same message Last edited by jadow; 03-15-2016 at 10:46. | |
03-15-2016, 14:31 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Update your Card-Reader Drivers: Drivers - http://server1.infinity-box.com/down...Fetian_FT2K.7z Instruction - http://server1.infinity-box.com/down...er_drivers.pdf Run Hua now. Result ? |
03-16-2016, 10:19 | #6 (permalink) | |
After you install drivers this result on xp | |
03-17-2016, 10:52 | #9 (permalink) |
Member: 954240 Status: Offline Thanks Meter: 7 | Science:- New activation for the first time did not work interface HUA not even once. The same problems Athlt firmware upgrade for the slide in this topic. http://forum.gsmhosting.com/vbb/f296...40/index3.html I tried to pass an update on DongleManager but I could not for the presence of Last Update Please note that these observations Tired I am suffering with this problem What is this HUA team ????? Please solve the problem or cancel the activation and returns money |
03-17-2016, 14:39 | #10 (permalink) | |
What is your other card-reader types ? | |
03-17-2016, 15:54 | #11 (permalink) | |
All give the same error message For your information interfaces Nokia and active cm2 by works perfectly The whole problem in this indefinite article HUA 1- BB5 Best Card Reader 2- MX KEY Card Reader 3- JAF Card Reader 4- Medusa Card Reader 5- SPT BOX Card Reader | |
03-17-2016, 18:59 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Pls test all readers one by one. Card-reade type (f.e. FT2000) you can read with this software: - Download http://server1.infinity-box.com/down...file=CardID.7z - Run CardID.exe - Select Card-Reader - Click to "Read" button pls post here your reader types. |
03-18-2016, 10:04 | #13 (permalink) | |
03-18-2016, 12:41 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Insert Smart-Card into Medusa reader and update Card with DongleManager now. Then run Hua. Result ? |
03-18-2016, 16:52 | #15 (permalink) | |
The problem has been resolved You mentioned your way Thank you for your help Thank you Tim Infinity-box And a very special thanks to the engineer YellowBoss The follow-up and support And Eng. PASSIONATE_BOYS | |
