Old 06-11-2011, 11:41   #1 (permalink)
andrew14's Avatar
Member: 78367
Thanks Meter: 11
Unhappy Needed flash file!!!!!!!!!!!!!!!!!
CT61G3_PCB01_GPRS_MT6225_S00.CT61G3_V3_6_ST_F1.BIN
i need this badly.....
i cant format this phone...
any opinion on this phone.... address on formatting or flash IC damage??
result on repair security.
COM7 [VCP1] selected
module v3.30
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: repair security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0B03:000A
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
New firmware found (v.3.30, database date: 29.05.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: CT61G3_PCB01_GPRS_MT6225_S00.CT61G3_V3_6_ST_F1.BIN
project-id: CT61G3_V3.6_ST_F1, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting startup code area #2...
startup code area #2 is absent
sec info (fast) detection...
searching sec info#1...
search sec info#1 finished
error: incorrect ffs address range
Finished, time used: 3 min 37 sec
Remove/Install battery now !
this one is from full format...
COM7 [VCP4] selected
module v3.30
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
flash: 2088C4BFFFBFFF:2088C400000000
Initialize Done
====> Set baud ...
921600
Set baud Done
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: _ffs...
warning: wrong data size at 0x00E8A800, retry...
read error recovered
warning: wrong data size at 0x00E96800, retry...
warning: wrong data size at 0x00F77800, retry...
warning: wrong data size at 0x00FE6C00, retry...
file saved: C:\InfinityBox\ChineseMiracle\_ffs_20110611-183527.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 3 min 49 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
and still dead.......
Old 06-12-2011, 05:31   #2 (permalink)
andrew14's Avatar
Member: 78367
Thanks Meter: 11
infinity support????
i cant upload the flashfile... if needed...
Old 06-12-2011, 07:30   #3 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
post your mobile compny & model name
Old 06-12-2011, 22:59   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
sorry, no such file in our collection
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.23250 seconds with 10 queries
