08-07-2017, 10:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | neffos x1 lite mt6755 invalid imei Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420752269BA1A359 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x354F6386F112663820E3ADF479E42CC1 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : Neffos ProdName : TP904A ProdModel : Neffos X1 Lite Device : X1_Lite AndroidVer: 7.0 MTKxCPU : MT6755 MTKxPRJ : alps-mp-n0.mp7-V1.24_tplink6750.65.n_P22 Done! Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : AT+EGMR=0,0 HW : AT+EGMR=0,4 SW : AT+EGMR=0,3 MM : AT+EGMR=0,1 VR : AT+EGMR=0,2 SN : AT+EGMR=0,5 Security Info : IMEI [1] : AT+EGMR=0,7 IMEI [2] : AT+EGMR=0,10 IMEI [3] : AT+EGMR=0,11 IMEI [4] : AT+EGMR=0,12 Read Ok! Update IMEI[1] to : 353921059700542 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:01:23 Reconnect Power/Cable! |
08-07-2017, 10:53 | #2 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | solved i repaire permanent mode 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420752269BA1A359 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x354F6386F112663820E3ADF479E42CC1 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Set IMEI [00] : 353921059700542 Prepare finished. Security check required! Wait for phone... Phone found! [ 34 ] Sync... Repair done! Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
